3086 2 2 0 |
05.03.2018, 15:53 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/review of Keeppower 18650 3500mAh P1835U (Blue-white) 2017
Official specifications:
A high capacity battery with build-in usb charger. The discharge curves tracks perfectly. The batteries do not get too hot at 5A. The overload protection is a bit temperature depend and one of the cells trips at 5A. Charging with the build-in charger, maximum charge current is about 0.8A and maximum charge time a bit below 7 hours. Termination is around 50mA. Conclusion Easy to use battery with protection and build-in charger. I will rate this a good battery. Notes and links The battery was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 06.03.2018 в 08:03] |
Поблагодарили: 2 раз(а) |
Witchdoctor (06.03.2018), Сумской (05.03.2018)
06.03.2018, 03:07 | 2 |
Регистрация: 20.10.2015 Последняя активность: Сегодня 04:49 Адрес: Владивосток
Сказал(а) спасибо: 3046
Поблагодарили: 1037 раз(а) в 627 сообщениях
Re: Test/review of Keeppower 18650 3500mAh P1835U (Blue-white) 2017
06.03.2018, 07:53 | 3 |
