217151 822 2 0 |
29.11.2017, 05:02 | 1 |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
3FVape - New products & Deals Update
Coppervape NarCA RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99
The Coppervape NarCA RDA Clone is a 22mm atty with fine finish and beloved appearance. Constructed from 316 stainless steel, its deck features dual post with large screws for easy building and gold plated positive pin for high conductivity. The airflow gets into the chamber via dual airslots and hits the side of coil directly, giving you great flavor and vapor production. 510 Ultem drip tip is included. This RDA comes with bottom feeder pin. Kindbright Kayfun Prime RTA Rebuildable Tank Atomizer Clone with Spare Tube $18.99 The Kindbright Kayfun Prime RTA Clone is constructed from 316 stainless steel with 22mm diameter and 2ml capacity. It features small chamber and narrow air channel for denser flavorful vapor. The deck is designed for only single coil. The 510 POM drip tip can protect mouth form heat. This RTA comes with extra extension glass tube and chimney to increase capacity.This iteam also has many color to choose. Original Vapjoy Ailly Pod Kit with 800mAh Battery $29.99 The Vapjoy Original Ailly Pod Kit is a convenient starter kit for beginners. It comes with 800mAh built-in battery and cartridge with pre-built 0.4ohm coil head. With the ergonomic design, compact size and simple operation, you can just take a puff wherever and whenever you like.This iteam also has many color to choose. Replacement Back Cover Panel for Octopus Mods Squonk Box Mod Clone $3.99 The replacement back cover panel is made from aluminum and is suitable for Octopusmods Squonk Box Mod Clone. Coppervape Spare Kit with BF Pin for NarCa RDA Clone $1.29 The Coppervape Spare Kit includes 1 bottom feeder pin, 2 screws and 6 o-rings and all are suitable for Coppervape NarCa RDA Clone. Coppervape Replacement 510 Delrin Drip Tip for NarCa RDA Clone $1.29 The Coppervape replacement 510 drip tip is made from Delrin with 10mm height. It is suitable for Coppervape NarCa RDA Clone.This iteam also has many color to choose. Coppervape Replacement Ultem Slammed Top Cap for NarCa RDA Clone $4.99 The Coppervape replacement slammed top cap is made from Ultem and is suitable for Coppervape NarCa RDA Clone. |
07.12.2017, 04:45 | 2 |
Re: 3FVape - New products & Deals Update
Original Vaporesso Transformer 220W TC VW Variable Wattage Box Mod $47.99
The Vaporesso Transformer is a multi-function device intended to let you vape with fun, which brings the interaction into vaping with its all-metal case fully replaceable, creating different looks that you like. It is powered by dual 18650 batteries (not included), the mod is capable of outputting up to 220W with up-to-date OMNI Board 2.6. The Transformer supports atomizer resistance low to 0.05ohm.This item also has many color to choose. Original Joyetech eVic Primo 2.0 228W TC VW Variable Wattage Box Mod $26.99 Powered by dual replaceable 18650 batteries (not included), the Original Joyetech eVic Primo 2.0 provides durability and reliability with a 228W maximum output. Featuring the new equalizing charge system, it supports 2.0A quick charge capability. The eVic Primo 2 also comes with upgradeable firmware, as well as multiple fashionable features including the real-time clock, custom logo and preheat.This item also has many color to choose. Kira RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.59 The Kira RDA Clone is constructed from stainless steel in 22mm diameter. The build deck features dual post design for single coil building. It comes with smooth airflow and is suitable for MTL vaping. Extra cap and 510 drip tip are included. Ulton Ding Prime RTA Rebuildable Tank Atomizer Clone $27.90 The Ulton Ding Prime RTA Clone is constructed from 316 stainless steel in 24mm diameter. It features Velocity style build deck for easy coil building, 8ml e-juice capacity, adjustable top airflow, reilling hole for top fill, etc. It supports both single and dual coil builds. Ultem drip tip is included, which protects your mouth from heat.This item also has many color to choose. This RTA is smooth version. Original KingTu KT-X RDA Rebuildable Dripping Atomizer with BF Pin $18.99 The Original KingTu KT-X RDA is a 24mm atty that features dual post design for easy building, adjustable side airflow for smooth vapor, gold plated positive pin for great conductivity, and both standard pin and squonk pin compatible. POM wide bore drip tip is included. This RDA comes with bottom feeder pin. Original SMOKTech SMOK Stick Prince 100W 3000mAh Mod + TFV12 Prince Tank Kit $38.99 The SMOK Stick Prince Kit consists of Stick Prince 3000mAh Battery Mod and TFV12 Prince Tank.This item also has many color to choose. Mod: The SMOK Stick Prince features 3000mAh built-in battery and is capable of outputting up to 100W, giving you great vaping experience. With large battery capacity, it is possible to vape for a long time. The newly designed hexagon power button looks special and can give you better hand-feel when you press it. Tank: The authentic SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 3 newest coils: V12 Prince Q4, V12 Prince X6 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. Original Vaporesso Transformer 220W TC VW Variable Wattage Mod + NRG Tank Kit $63.99 The Vaporesso Transformer Kit consists of Vaporesso Transformer Mod and NRG Tank.This item also has many color to choose. Mod: The Vaporesso Transformer is a multi-function device intended to let you vape with fun, which brings the interaction into vaping with its all-metal case fully replaceable, creating different looks that you like. It is powered by dual 18650 batteries (not included), the mod is capable of outputting up to 220W with up-to-date OMNI Board 2.6. The Transformer supports atomizer resistance low to 0.05ohm. Tank: The NRG Tank by Vaporesso is a master piece of everyday vape and cloud chasing, featuring innovative GT Cores that comes in traditional and CCELL Ceramic coil. The Slide-n-Fill design makes refill easier than ever. The heating insulation layer on the bottom demonstrates how Vaporesso care for safer and relaxing vaping experience. Furthermore, the mesh drip tip with specially engineered structure will prevent any spit back. Enjoy the flavor and vapor out of the variety of GT cores available. Original Vaporesso Transformer LE 220W TC VW Variable Wattage Mod + NRG Tank Kit $65.99 The Vaporesso Transformer Kit consists of Vaporesso Transformer Mod and NRG Tank.This item also has many color to choose. Mod: The Vaporesso Transformer is a multi-function device intended to let you vape with fun, which brings the interaction into vaping with its all-metal case fully replaceable, creating different looks that you like. It is powered by dual 18650 batteries (not included), the mod is capable of outputting up to 220W with up-to-date OMNI Board 2.6. The Transformer supports atomizer resistance low to 0.05ohm. This mod is LE version with lighting effects. Tank: The NRG Tank by Vaporesso is a master piece of everyday vape and cloud chasing, featuring innovative GT Cores that comes in traditional and CCELL Ceramic coil. The Slide-n-Fill design makes refill easier than ever. The heating insulation layer on the bottom demonstrates how Vaporesso care for safer and relaxing vaping experience. Furthermore, the mesh drip tip with specially engineered structure will prevent any spit back. Enjoy the flavor and vapor out of the variety of GT cores available. Death Knight PVC Wrapper Skin Sticker for 18650 Battery $1.49 The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. This product comes with 10 PCS in one pack. YFTK Replacement Drip Tip + Top Cap Kit for NarCa RDA Clone $6.59 The replacement drip tip and top cap are made from PC and is suitable for YFTK NarCa RDA Clone.This item also has many color to choose. SXK Replacement Tank Tube for KF Prime RTA Clone $3.59 The replacement tank tube is made from PC and is suitable for SXK KF Prime RTA Clone. |
08.12.2017, 04:53 | 3 |
Original Rofvape Naga 330W TC VW Variable Wattage Box Mod Original Price $65.99,Now Only $55.99
The Original Rofvape Naga Mod utilizes triple 18650 batteries (not included) and is capable of outputting up to 330W. It features elegantly ergonomic design and stunning appearance. It is equipped with 0.9inch OLED display screen to show real time and vaping data. Comes with multiple protections, this mod would be safe to vape with high performance.This item also has many color to choose. Original Hades BF Bottom Feeder Squonk Mechanical Box Mod $24.99 The Original Hades BF Squonk Box Mod comes with colorful resin chassis and brass contact for better conductivity. It has 10ml built-in squonk bottle. The cover panel is magnetic style. The mod is powered by a single 18650 battery (not included).This item also has many color to choose. Solo RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The Solo Style RDA is constructed from 316 stainless steel in 22mm diameter. It features two post for single coil building and top-side adjustable airflow. POM drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Lucid RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.59 The Lucid Style RDA is constructed from stainless steel in 22mm diameter. The RDA has a unique build deck, which is similar to velocity deck but adopts clamp design. The side-mounted screws is all spring-loaded. It can support vertical coil builds. The gold plated deck provides great conductivity. The cap comes with quad airholes and dual airslot for different configurations.This item also has many color to choose. This RDA comes with bottom feeder pin. Original KingTu KT-X RDA Rebuildable Dripping Atomizer with BF Pin $17.99 The authentic KingTu KT-X RDA is a 24mm atty that features dual post design for easy building, adjustable side airflow for smooth vapor, gold plated positive pin for great conductivity, and both standard pin and squonk pin compatible. POM wide bore drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. S-Rabbit Squonk Mechanical Box Mod Clone + Solo RDA Clone Kit $17.99 The mod kit consists of S-Rabbit Style Squonk box mod and Solo Style RDA.This item also has many color to choose. Mod: The S-Rabbit Style Squonk box mod is made out of Nylon material and features 8ml silicone bottom feeder bottle for squonking. The mod comes with the adjustable 510 pin, flip style battery access door and gold plated contact plate for better conductivity. It is powered by 1 x 18650 battery (not included). RDA: The Solo Style RDA is constructed from 316 stainless steel in 22mm diameter. It features two post for single coil building and top-side adjustable airflow. POM drip tip is included. This RDA comes with bottom feeder pin. Replacement Tank Tube for Digiflavor Pharaoh Mini RTA $1.99 The replacement glass tank tube is suitable for authentic Digiflavor Pharaoh Mini RTA and can hold 2ml e-juice. Replacement Tank Tube for Augvape Merlin MTL RTA $1.99 The replacement glass tank tube is suitable for authentic Augvape Merlin MTL RTA. Replacement Tank Tube for Digiflavor Pharaoh Mini RTA $1.99 The replacement glass tank tube is suitable for authentic Digiflavor Pharaoh Mini RTA and can hold 5ml e-juice. |
11.12.2017, 04:20 | 4 |
Original Smoant Battlestar Mini 80W TC VW Variable Wattage Box Mod $27.99
The Original Smoant Battlestar Mini is the mini version of Smoant Battlestar, with smaller size, ergonomic design and various working modes. Powered by single 18650 battery (not included), it is capable of outputting up to 80W. With a 0.96 inch big OLED display, it is clear to view all vaping data. Battlestar Mini comes with VW, Bypass, TC (Ni, Ti, SS), TCR and DVW modes, which gives a lot of fun to advanced vaper to play with what they want.This item also has many color to choose. Scepter Hybrid Mechanical Mod Clone $24.99 The Scepter mechanical mod Clone is constructed from brass with copper battery contact. The mod features twisted design and engraved millings and patterns. It comes with top venting holes and magnetic fire button. The mod is powered by single 18650 battery (not included).This item also has many color to choose. SXK KF Prime RTA Rebuildable Tank Atomizer Clone $26.00 The SXK KF Prime RTA Clone is constructed from 316 stainless steel with 22mm diameter and 2ml capacity. It features small chamber and narrow air channel for denser flavorful vapor. The deck is designed for only single coil. The 510 POM drip tip can protect mouth form heat.This item also has many color to choose. SXK Narca RDA Rebuildable Dripping Atomizer Clone with BF Pin $15.90 The SXK Narca RDA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single coil building. The airflow is adjustable with the airslots on the cap. POM heat resistant drip tip is included.This item also has amny color to choose. This RDA comes with bottom feeder pin. Original Vapefly Mesh Plus RDA Rebuildable Dripping Atomizer with BF Pin $34.99 The Original Vapefly Mesh Plus RDA is another fantastic mesh-concept atty, with 316 stainless steel construction, 25mm diameter, postless build deck for mesh wire, single coil or dual coil builds. There are 4 terminals with quad individual clamp, which make coil building much easier. The airflow is adjustable with the dual airslots on the cap. 810 Delrin drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Original Smoant Battlestar Nano 80W Box Mod + Battlestar RDA Kit $25.99 The Original Smoant Battlestar Nano Kit consists of Smoant Battlestar Nano Mod and Battlestar RDA.This item also has many color to choose. Mod: The authentic Smoant Battlestar Nano Mod features compact size with 80W full power output. It comes with big fire button and supports USB charging. The mod is powered by single 18650 battery (not included). RDA: The authentic Smoant Battlestar RDA is a 24mm dripper constructed from aluminum and PEEK insulator. The deck is wide and deep, featuring dual post design and 8mm juice well. The airflow is adjustable with the help of dual airslots on on the cap, giving direct inflow towards the coil. Besides, the cap was designed as a funny face, which looks cute. 810 Ultem drip tip is ready for the RDA, which is heat-resistant and can protect your mouth. Original Aspire Revvo Replacement ARC Coil $9.50 The fantastic all new coil design, the ARC, Aspire Radial Coil, sits horizontally in the tank similar to a stove-top design. Of course the real trick in the design is the increased surface area of the coil for great flavor and great vapor production rated at 0.10~0.16ohm using Kanthal AF wire. It work well at 50~100W, best at 80~85W. This product comes with 3PCS in 1 pack. Miku PVC Wrapper Skin Sticker for 18650 Battery - 10 PCS $1.49 The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. This product comes with 10 PCS in one pack.This item also has many patterns to choose. |
12.12.2017, 05:06 | 5 |
Bravo Box Bottom Feeder Squonk Mechanical Box Mod Clone $14.99
The Bravo Box Squonk Box Mod Clone is a convenient squonking device with large fire button and 7ml built-in bottle, which should satisfy your daily use. Most importantly, the mod support single 18650 / 20700 / 21700 battery (not included), which makes it compatible with various kinds of batteries.This item also has many color to choose. Underground BF Squonk Mechanical Box Mod Clone $25.99 The Underground Squonk Box Mod Clone is constructed from PEI and brass and comes with 8ml silicone squonk bottle. The connector fits atomizers not over 25mm diameter. The fire button is positioned on top. Powered by single 18650 or 20700 battery (not included), this mod will provide raw power for your vaping. Original Tesla WYE 85W TC VW Variable Wattage Box Mod $39.99 The new Tesla WYE 85W Mod is constructed from ABS and PC, making it more lightweight and portable. It is powerful as it can output up to 85W and supports Ni200 / Ti / SS316 / TCR temperature control function. Other modes like taste mode, memory mode are also included, giving you more fun to vape. The mod is powered by single 18650 battery (not included) and supports USB charging.This item also has many color to choose. Original GeekVape Ammit Dual Coil Version RTA Rebuildable Atomizer Original Price $30.99,Now Only $22.99 Please log in to see the lower price. The Ammit dual coil version has been upgraded with the new 20mm build deck to support dual coil option and easier to build on. The innovative four-path airflow system which combines bottom and side flow will surely make this RTA an unmatchable cloud beast and flavor machine.This item also has many color to choose. Kindbright NarCa RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.99 The Kindbright Narca RDA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single coil building. The airflow is adjustable with the airslots on the cap. POM heat resistant drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Replacement Tank Tube for Augvape Boreas V2 RTA $1.99 The replacement tank tube is made from glass with 5ml capacity. It is suitable for authentic Augvape Boreas V2 RTA. 810 Wide Bore Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA - Random Color $1.99 The 810 drip tip is made from Epoxy resin with 17mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped by random color (one piece). More options than what's on the image. 810 Wide Bore Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99 The 810 drip tip is made from PEI and resin with 17mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. 810 Wide Bore Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA - Random Color $2.99 The 810 drip tip is made from Epoxy resin and brass with 21mm height. It comes with adjustable airflow design. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped by random color (one piece). More options than what's on the image. 810 Wide Bore Drip Tip for 528 Goon / Kennedy / Reload RDA - Random Color $2.99 The 810 drip tip is made from Epoxy resin and stainless steel with 14mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped by random color (one piece). More options than what's on the image. 810 Wide Bore Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA - Random Color Epoxy Resin + SS $2.99 The 810 drip tip is made from Epoxy resin and stainless steel with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped by random color (one piece). More options than what's on the image. Original Athena Charging Base for Quick 2.4 Vaporizer $8.99 The charging base is suitable for Original Athena Quick 2.4 Vaporizer. Original Athena Replacement Heating Head for Quick 2.4 Vaporizer $8.99 The heating head is suitable for Original Athena Quick 2.4 Vaporizer. |
13.12.2017, 05:03 | 6 |
Sentinel RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
The Sentinel RDA Clone is constructed from stainless steel in 22mm diameter. The deck features dual post design for single coil build. The airflow can be adjusted with the top airflow ring and angled airslots. A heat resistant POM drip tip is included for the RDA.This item also has many color to choose. The RDA comes with bottom feeder pin. KF Prime RTA Rebuildable Tank Atomizer Clone $17.99 The KF Prime RTA Clone is constructed from 316 stainless steel with 22mm diameter and 6ml capacity. It features small chamber and narrow air channel for denser flavorful vapor. The deck is designed for only single coil. The 510 POM drip tip can protect mouth form heat.This item also has many color to choose. KF 5.2 RTA Rebuildable Tank Atomizer Clone $18.99 The KF 5.2 RTA Clone is a 25mm tank constructed from 316 stainless steel. It features top filling design, maximum 7ml e-juice capacity, dual post deck for single coil building, e-liquid flow control function and adjustable bottom airflow. It will definitely bring you great vaping experience. Original Smokjoy Pyramid RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99,Now Only $22.99 Please log in to see the lower price. The Original Smokjoy Pyramid RDA is a 24mm atty that adopts innovative design for its posts, the Pyramid style post, which allows vapers to build coils much easier. The gold plated deck and positive pin provides great conductivity. The airflow is adjustable with dual airslots on the cap. 810 delrin drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Modfather Inc RTA Rebuildable Tank Atomizer Clone $20.99 The Modfather Inc RTA Clone is constructed from 316 stainless steel and features huge size, which is 30mm diameter and the tank can hold 9ml of e-juice. The build deck adopts classic velocity style design and is removable. Every part becomes larger to allow you to achieve various builds! The adjustable airflow blows to the coil directly. POM drip tip is included.This item also has many color to choose. Original Xohm O1 650mAh Starter Kit Original Price $25.00,Now Only $19.99 Please log in to see the lower price. The Original Xohm O1 kit consists of a pen style 650mAh battery and a MTL X1 tank.This item also has many color to choose. Mod: The Xohm O1 is a pen style kit for convenient use, which is lightweight and portable. It has built-in 650mAh battery and supports USB charging. It comes with indicator light around the fire button indicates the battery level. Tank: The MTL X1 tank features 2ml juice capacity, convenient top fill design and bottom airflow. It adopts a 1.6ohm coil for vaping, which works well at 10~12W. Original Xohm O2 2600mAh Starter Kit Original Price $39.00,Now Only $28.79 Please log in to see the lower price. The Original Xohm O2 kit consists of a pen style 2600mAh battery and a X2 tank.This item also has many color to choose. Mod: The Xohm O2 is a pen style kit for convenient use, which is 24mm in diameter. It has built-in 2600mAh battery and supports USB charging. It comes with indicator light around the fire button indicates the battery level. Tank: The X2 tank features 4ml juice capacity, convenient top fill design and bottom airflow. It adopts a 0.3ohm coil for vaping, which works well at 40~48W. Original Xohm M1 75W TC VW Variable Wattage Box Mod + X3 Tank H1 Kit Original Price $57.00,Now Only $37.89 Please log in to see the lower price. The Original Xohm H1 kit consists of a M1 TC VW mod and a X3 tank.This item also has many color to choose. Mod: The Xohm M1 features compact size and ergonomic design for comfortable hand-feel. Powered by single 18650 battery (not included), it is capable of outputting up to 75W. The mod supports VV / VW / Bypass / TC / TCR / CPS modes and the supporting resistance is from 0.1 to 3.5ohm. Tank: The X3 tank features 22mm diameter, 2.6ml juice capacity convenient top fill design and adjustable airflow, which allow you to customize airflow with 6 pairs of airflow holes. The tank comes with a 0.6ohm coil pre-installed, which is rated for 25~30W, and a 0.3ohm coil rated for 40~50W. Original Xohm H2 5000mAh TC Temperature Control Box Mod + X4 Tank Kit Original Price $68.00,Now Only $42.99 Please log in to see the lower price. The Original Xohm H2 kit consists of a H2 mod and a X4 tank.This item also has many color to choose. Mod: The Xohm H2 mod features a large capacity 5000mAh built-in battery, which allows longer vaping time. Comes with 0.96inch OLED display to view vaping data and supports USB charging. Tank: The X4 tank features 3.5ml juice capacity convenient top fill design and will bring you awesome flavor and vapor production. |
14.12.2017, 04:23 | 7 |
Original IJOY EXO PD270 207W TC VW Variable Wattage Box Mod $42.99
IJOY introduces another dual 20700 device, the IJOY EXO PD270 BXO MOD, featuring sleek design with RGB backlight and powerful output. With dual 20700 batteries (not included), EXO PD270 is capable of outputting from 5 to 207W. 18650 battery also works with adapter tube. The Unique wrinkle finish allows the mod to be anti-scratch, anti-fingerprint and wear-resistant. Temperature control suite includes NI / TI / SS / TCR mode. The atomizer resistance range is from 0.05 to 3.0 ohm. 25mm tanks will not overhang on EXO PD270. The USB port supports charging and firmware upgraging. This mod comes without any battery.This item also has many color to choose. Original IJOY EXO PD270 207W TC VW Variable Wattage Box Mod with Battery $55.99 IJOY introduces another dual 20700 device, the IJOY EXO PD270 BXO MOD, featuring sleek design with RGB backlight and powerful output. With dual 20700 batteries (included), EXO PD270 is capable of outputting from 5 to 207W. 18650 battery also works with adapter tube. The Unique wrinkle finish allows the mod to be anti-scratch, anti-fingerprint and wear-resistant. Temperature control suite includes NI / TI / SS / TCR mode. The atomizer resistance range is from 0.05 to 3.0 ohm. 25mm tanks will not overhang on EXO PD270. The USB port supports charging and firmware upgraging. This mod comes with 2 x 20700 batteries.This item also has many color to choose. Original Ample Mace RDA Rebuildable Dripping Atomizer with BF Pin $21.99 The Original Ample Mace RDA features M5 Big Screws that fixed in the dual optimized clamp posts, which makes coil building much easier and supports all kinds of coils. The innovative middle prismatic airflow allows massive vapor production and pure flavor. You can directly refill the e-juice through the 810 wide bore drip tip, or you can do it via the squonk pin.This item also has many color to choose. This RDA comes with bottom feeder pin. Headshot RDA Rebuildable Dripping Atomizer Clone $8.99 The Headshot RDA Clone is constructed from stainless steel (cap) and brass (base) in 24mm diameter. The build deck has a T-clamp positive post and dual negative post, which allows you to DIY various types of coils. The side airflow hits the coil directly without any adjustable mechanism.This item also has many color to choose. Original Silenremem Killing Time RDA Rebuildable Dripping Atomizer $25.99 The Original Silenremem Killing Time RDA is a competition atty designed for massive vapor production. It is 24mm diameter and features clamp dual post design, dual airflow. The clamp adopts spring design to make building more convenient. The RDA comes with bottom airflow and adjustable side airflow. The PEI drip tip has some grooves on the inner side, which can prevent the condensation. Killing Time RDA is suitable for those who chase huge amount of vapor, and nice flavor at the same time.This item also has many color to choose. Original Sprint Organic Cotton Ball for Coil Building / Wicking $3.99 The Original Sprint cotton is super soft and pure ball shape cotton for vaping. It is taken with proprietary purification process to remove impurities, natural oils and pesticides. The medical level facilities make sure all processing are carefully treated and 100 percent tasteless cotton for wicking. This product comes with 12 PCS cotton in 1 pack. Dripping Dropper Bottle for Bottom Feeder Squonk Mod $5.99 This dripping dropper bottle is made from PE and stainless steel lid and has 60ml e-juice capacity. It is used for squonk bottom feeder mods which have built-in bottles. It can feed the built-in bottle with e-juice via the 510 connector. Only for bottom feeder mods that come with built-in bottle. Replacement Wide Bore Drip Tip / Top Cap for 24mm RDA / 24mm Goon RDA $1.59 The wide bore drip tip / top cap is suitable for 24mm RDA, such as 24mm Goon RDA. The drip tip is with 11.5mm inner bore diameter. 810 Wide Bore Drip Tip for 528 Goon / Kennedy / Reload RDA $1.49 The 810 drip tip is made from PC with 95mm height. It can used as 510 drip tip adapter too. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. 810 Wide Bore Drip Tip for 528 Goon / Kennedy / Reload RDA $1.29 The 810 drip tip is made from POM with 10.8mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose. eGo One 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.39 The replacement eGo One 510 drip tip is made from POM. It is suitable for all atomizers that fit 510 drip tip.This item also has many color to choose. Heat Insulator for 24mm RDA / RTA / Sub Ohm Tank Atomizer $1.39 The heat insulator is made from PEI and is used for 24mm RDA / RTA / Sub Ohm Tank. Golisi O4 2A Economic Quick Charger $18.99 The Golisi O4 is an intelligent battery charger; featuring 2A fast charging, no-button operation, fire-proof design, with an automatic current distribution and anti-reverse connection protection. With the O4 charger, your batteries can be charged quickly and safely. This charger is US plug.This item also has a EU plug version to choose. Original Golisi IMR 26650 4300mAh 3.7V 35A Flat Top Rechargeable Battery $11.59 Golisi IMR 26650 Battery, featuring a diameter of 26mm and a length of 65mm, has a 4300mAh large battery capacity with 35A max continuous discharging current. Long storage life, light weight and high energy density. Original Golisi S30 IMR 18650 3000mAh 3.7V 35A Flat Top Rechargeable Battery $20.99 Golisi S30 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 3000mAh large battery capacity with 35A max continuous discharging current. Long storage life, light weight and high energy density. This product comes with 2 pieces (2 PCS) of batteries. Original Golisi G30 IMR 18650 3000mAh 3.7V 25A Flat Top Rechargeable Battery $14.99 Golisi G30 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 3000mAh large battery capacity with 25A max continuous discharging current. Long storage life, light weight and high energy density. This product comes with 2 pieces (2 PCS) of batteries. Original Golisi G25 IMR 18650 2500mAh 3.7V 25A Flat Top Rechargeable Battery $12.99 Golisi G25 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 2500mAh large battery capacity with 25A max continuous discharging current. Long storage life, light weight and high energy density. This product comes with 2 pieces (2 PCS) of batteries. Original Golisi S35 IMR 21700 3750mAh 3.7V 40A High Drain Rechargeable Battery $13.99 Golisi S35 IMR 21700 Battery, featuring a diameter of 21mm and a length of 70mm, has a 3750mAh large battery capacity with 40A max continuous discharging current. The battery offers better performance at higher temperatures and also heats up less when undergoing high-current discharges. This product comes with only one piece of battery. SXK Replacement Top Cap for NarCa RDA Clone $3.99 The replacement top cap is made from PC and is suitable for SXK NarCa RDA Clone. This product comes with only one piece (1 PC). 510 / eGo Adapter for RDA / RTA / Sub Ohm Tank Atomizer $1.99 The adapter is made from stainless steel and used for atomizers with 510 / eGo connection. |
15.12.2017, 04:28 | 8 |
Original Hugo Vapor Squeezer BF Squonk Mechanical Box Mod $25.99
The Original Hugo Squeezer BF Squonk Mod is a handy squonker that comes with 10ml built-in silicone bottle. The Squeezer consists of Nylonfibre shell, gold plated 510 connector and special copper contacts. It is convenient to use without refilling frequently. The mod is powered by a single 20700 / 18650 (18650 adapter needed, batteries not included). Phantohm Bottom Feeder Squonk Mechanical Box Mod Clone $19.99 The Phantohm Mechanical Box Mod Clone is a mini size mod with 6.5ml soft bottle inside for squonking. The mod is constructed from PEI and the contacts are copper made. The mod can be used with 22mm to 24mm diameter atomizers. It is powered by 1 x 18650 battery (not included).This item also has many color to choose. Zenetik Mechcanical Box Mod Clone $14.99 The Zenetik Mechanical Mod Clone is constructed from POM and brass. It features sleek ergonomic design, which gives you most comfortable hand-feel when operating. The POM fire button is easy to press with your thumb. The mod is powered by single 18650 battery (not included).This item also has many color to choose. Zenetik Mechcanical Box Mod Clone - Random Color $14.99 The Zenetik Mechanical Mod Clone is constructed from resin and brass. It features sleek ergonomic design, which gives you most comfortable hand-feel when operating. The POM fire button is easy to press with your thumb. The mod is powered by single 18650 battery (not included). This mod will be shipped by random color. Original Tesla Punk 220W TC VW Variable Wattage Box Mod $55.99 Tesla keeps its steam punk style design and introduces the Tesla Punk box mod. You will be impressed by the steampunk style PCB, which you can see through the transparent PC panel. Powered by dual 18650 batteries, the maximum output of Punk can reach up to 220W. The ergonomic design, bright OLED screen, and multiple working modes will make your vaping comfortable and joyful.This item also has many color to choose. Original OMG CDA RTA Rebuildable Tank Atomizer $43.69 The Original OMG CDA RTA is a 25mm tank with 2ml juice capacity. It features unique spin buckle design for RDA / RTA mode, bayonet-type top filling, dual post build deck and adjustable bottom airflow, which will bring you excellent vaping experience.This item also has many color to choose. Original Desire Mad Dog V2 RDA Rebuildable Dripping Atomizer $27.99 The Desire Mad Dog V2 RDA is the upgraded version of Mad Dog RDA. It features sleek design, easy-to-build deck and side airflow. The RDA will give you different vaping experience.This item also has many color to choose. Kindbright Speed Up RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.99 The Kindbright Speed Up RDA Clone is constructed from 316 stainless steel in 18mm diameter. It features dual post build deck for single coil building. The juice well can hold much e-juice as it is very deep. The airflow is adjustable with single airslot on the cap. The POM 510 drip tip is heat resistant and can protect your mouth from heat.This item also has many color to choose. This RDA is squonk-ready with bottom feeder pin, no standard pin included. Original Iwodevape Protective Case Sleeve for Quad 18650 Batteries $2.59 The Original Iwodevape Protective Case Sleeve is made from silicone and is used to storage and protect your 18650 batteries. It can hold 4 batteries.This item also has many color to choose. Original Iwodevape Protective Case Sleeve for Triple 18650 Batteries $1.99 The Original Iwodevape Protective Case Sleeve is made from silicone and is used to storage and protect your 18650 batteries. It can hold 3 batteries.This item also has many color to choose. |
16.12.2017, 04:56 | 9 |
Original Snowwolf 200W-R 235W TC VW Variable Wattage Box Mod Original Price $75.99,Now only $55.99
The Original Snowwolf 200W-R Box Mod is a versatile device that supports various types of working modes, like variable wattage mode, temperatures control mode, TCR mode. Powered by dual 18650 batteries (not included), the mod is capable of outputting up to 235W, giving you impressive vaping experience.This item also has many color to choose. Original ISK Armor Sub Ohm Tank Atomizer $13.99 The Original ISK Armor Atomizer is a 24mm tank with 2.3ml e-juice capacity. By taking off the stainless steel cap, there is an internal glass tube, where you can refill juice directly without leaking. The coil is Ni80 0.3 ohm single core rated for 30 to 80W. The drip tip adopts honeycomb air path design on the bottom, and is very close to the coil, which will bring you smooth vapor and pure flavor.This item also has many color to choose. Underground RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99 The Underground Style RDA is a 25mm atty constructed from stainless steel. The deck is larger with dual post, deeper juice well and wider bottom air paths. The RDA comes with both side and bottom airflow. Removable wide bore resin drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Original YC Vape F-Tower RDA Rebuildable Dripping Atomizer with BF Pin $10.99 The YC Vape F-Tower RDA is constructed from stainless steel in 18mm diameter. The deck comes with dual post design for only single coil building. The airflow passes through the side holes on the cap and the perforated posts and hits the coil directly. The inner side of the cap becomes narrower and finally domed at the top, which gives you denser vapor and purer flavor.This item also has many color to choose. This RDA comes with 22mm adapter ring and bottom feeder pin. Original Bravo Box Squonk Mechanical Box Mod + BF RDA Kit $20.99 The Original Bravo Box Squonker Kit consists of Bravo Box Mod and Bravo BF RDA.This item also has many color to choose. Mod: The Original Bravo Box Squonk Box Mod is a convenient squonking device with large fire button and 7ml built-in bottle, which should satisfy your daily use. Most importantly, the mod support single 18650 / 20700 / 21700 battery (not included), which makes it compatible with various kinds of batteries. RDA: The Bravo BF RDA is a 24.7mm atty that suitable for squonking. The deck features classic velocity dual post design for easy coil building, 8mm deep juice well to storage a ton of e-juice, adjustable bottom airflow. It comes with 810 wide bore drip tip and you can even dripping through the drip tip or just bottom feeding. This RDA comes with bottom feeder pin. SXK Replacement Bottom Feeder Pin + Positive Post for M-Atty RDA Clone $2.99 The replacement bottom feeder pin and positive post is made from gold plated stainless steel and is suitable for SXK M-Atty RDA Clone. Original ISK Replacement Coil Head for Armor Sub Ohm Tank Atomizer $9.99 The replacement coil head features 0.3ohm resistance and is rated for 30~80W. It is suitable for authentic ISK Armor Atomizer. This product comes with 5 PCS in 1 pack. Replacement Bubble Glass Tank Tube for Digiflavor Pharaoh Mini RTA $1.99 The replacement bubble glass tank tube can hold 5ml of e-juice and is suitable for original Digiflavor Pharaoh Mini RTA. Original YC Vape Siphon Juice Tank Adapter for 18mm / 22mm / 24mm BF RDA / RTA $10.99 The Original YC Vape Juice Tank Adapter is an innovative Siphon accessory used on bottom feeder RDA / RTA. It is a 24mm adapter and can compatible with atomizers not over 24mm. With this adapter, it allows your BF RDA / RTA to work well on a non-squonk device and hold extra 4ml of e-juice. It is suitable for those who have bottom feeder atomizers but are not willing to buy a squonk device. |
18.12.2017, 04:42 | 10 |
Original Rofvape Witcher XER 90W TC VW Variable Wattage Box Mod Original Price $39.99,Now Only $35.99
The Rofvape Witcher XER Mod features compact size and stylish design with a symmetrical "X" on the side. Powered by single 18650 battery (not included), the mod is capable of outputting up to 90W. It supports atomizer resistance from 0.05 to 3ohm. The 27mm gold plated 510 connector can be compatible with most of the atomizers in the market.This item also has many color to choose. Original Joyetech Elitar Pipe 75W TC VW Variable Wattage Box Mod $14.99 Classics never go out of style. The Elitar Pipe is cool, sophisticated and elegant in appearance. It brings you back to the old days with its timeless classic design and premium finish. Powered by single 18650 battery (not included) with 75W maximum output, Elitar presents a 0.66-inch OLED screen, having TC / Power / BYPASS / TCR modes available. Featuring an upgradeable firmware, the Elitar Pipe can perfectly satisfy you on a daily basis.This item also has many color to choose. Original Blitz Ghoul RDA Rebuildable Dripping Atomizer with BF Pin Original Price $26.90,Now Only $18.99 Please log in to see the lower price. The Original Blitz Ghoul BF RDA adopts innovative design on the building post, which is an integrated post with ceramic clamp for single coil building. The tank comes with side airflow, which is adjustable. Gold plated positive pin provides great conductivity. Resin and acrylic drip tips are included. This RDA comes with bottom feeder pin. Original Rofvape Witcher XER 90W TC VW Variable Wattage Box Mod + Tank Kit Original Price $54.99,Now Only $47.99 The Original Rofvape Witcher XER Kit consists of Rofvape Witcher XER Mod and Witcher XER Tank.This item also has many color to choose. Mod: The Rofvape Witcher XER Mod features compact size and stylish design with a symmetrical "X" on the side. Powered by single 18650 battery (not included), the mod is capable of outputting up to 90W. It supports atomizer resistance from 0.05 to 3ohm. The 27mm gold plated 510 connector can be compatible with most of the atomizers in the market. Tank: The Rofvape Witcher XER Tank is a 22mm tank with 2ml e-juice capacity. It features convenient top filling, bottom airflow for smooth vapor, and pre-installed 1.0ohm coil. Original Golisi S15 IMR 18650 1500mAh 3.7V 35A Flat Top Rechargeable Battery - Black (2 PCS) $12.99 Golisi S15 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 1500mAh large battery capacity with 35A max continuous discharging current. Long storage life, light weight and high energy density.This item also has a 2600mAh version to choose. This product comes with 2 pieces (2 PCS) of batteries. 810 to 510 Drip Tip Adapter for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.29 The 810-to-510 drip tip adapter is made from POM. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose. 510 Replacement Drip Tip + Beauty Adapter Ring Kit for 22mm Atomizer $4.99 The replacement 510 drip tip is made from POM. It is suitable for all atomizers that fit 510 drip tip. It measures 12mm in diameter and 10mm in height. The beauty adapter ring is made from POM. It is suitable for 22mm RDA / RTA / Sub ohm tank. The outer diameter is 24mm and inner is 22mm. |
20.12.2017, 04:58 | 11 |
Original Joyetech ESPION 200W TC VW Variable Wattage Box Mod $43.99
The Joyetech ESPION Mod features 200W maximum output and multiple working modes for different vaping experience, including Power, RTC, TC, TCR output modes. Coming with a 1.45 inch TFT colorful screen, it is easy to view vaping datas and time. The mod is powered by dual 18650 batteries (not included) and supports USB quick charging. Original OBS Damo Sub Ohm Tank Clearomizer $22.99 The Original OBS Damo Tank is a 25mm sub ohm tank that features 5ml large capacity, easy top filling with hidden side filling hole, narrow chimney and beveled drip tip for dense vapor, and wide airslots for bottom airflow, which is adjustable. There are two options for the coil: the 0.4ohm M2 coil rated for 30~50W, the 0.2ohm M6 coil rated for 40~100W.This item also has many color to choose. Original IJOY Captain Elite RTA Rebuildable Tank Atomizer $21.99 The Original IJOY CAPTAIN ELITE RTA is a new-designed MINI single coil RTA with good balance between pure flavor and massive vapor production. It is a 22.5mm tank with 2ml capacity, which can be extended to 3ml with extra bubble tank. It features sliding mechanism for convenient top filling, both DIY coil and pre-built coil head compatible, gold plated deck with side bottom airflow, which provides unique airflow for smooth vapor.This item also has many color to choose. NarCa RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Narca RDA Clone is constructed from stainless steel in 22mm diameter. The deck features dual post design for single coil building. The airflow is adjustable with the airslots on the cap. POM heat resistant drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Original IJOY Capo 100W 3000mAh Squonk Box Mod + SRDA Kit with Battery $49.99 The IJOY CAPO SRDA Kit consists of IJOY CAPO 100W Squonk Mod and IJOY SRDA.This item also has many color and a without battery version to choose. Mod: The Original IJOY Capo Squonk Box Mod is an innovative regulated squonker that is compatible with 18650 / 20700 / 21700 battery. It features 100W maximum power and 9ml food grade soft silicone bottle for squonking. With high performance capability and functionality, this bottom feeder Capo squonker will be the perfect device for a squonking experience. This mod comes with 1 x 20700 battery (3000mAh). RDA: The Original IJOY COMBO SRDA is the first RDA using pre-made coil, which is a subversive innovation of RDA, with revolutionary significance. There is no need to build coils by yourself. The COMBO SRDA can be disassembled, cleaned and replace the cotton with special wrench equipped to achieve the purpose of repeated use. The side airflow control is adjustable to provide cloudy vapor. It comes with wide bore 810 ultem drip tip, which is dripping compatible. This RDA comes with bottom feeder pin. Original Joyetech ESPION 200W TC VW Variable Wattage Box Mod + ProCore X Tank Kit $57.99 The Original Joyetech ESPION Kit consists of ESPION box mod and ProCore X Tank. Mod: The Joyetech ESPION Mod features 200W maximum output and multiple working modes for different vaping experience, including Power, RTC, TC, TCR output modes. Coming with a 1.45 inch TFT colorful screen, it is easy to view vaping datas and time. The mod is powered by dual 18650 batteries (not included) and supports USB quick charging. Tank: The Joyetech ProCore X Tank comes with 2ml e-juice capacity and can be changed to 4.5ml with extension tube. It features convenient top filling and bottom airflow for smooth vapor. Original OBS Replacement M2 Coil Head for Damo Sub Ohm Tank Atomizer $10.99 The replacement M2 coil features 0.4ohm resistance and works well at 30~50W (best 35~45W), which is suitable for authentic OBS Damo Sub Ohm Tank. This product comes with 5 PCS in 1 pack. Original OBS Replacement M6 Coil Head for Damo Sub Ohm Tank Atomizer $10.99 The replacement M6 coil features 0.2ohm resistance and works well at 40~100W (best 60~80W), which is suitable for authentic OBS Damo Sub Ohm Tank. This product comes with 5 PCS in 1 pack. Replacement 510 Drip Tip + Top Cap Kit for NarCa RDA Clone $2.99 The replacement 510 drip tip and top cap is made from PC and is suitable for NarCa RDA Clone. This item also has many color to choose. |
21.12.2017, 04:52 | 12 |
HK25 Smooth Hybrid Mechanical Mod Clone $14.99
The AV HK Smooth mod Clone comes with 25mm battery tube. It features simple design with a fixed 510 hybrid top to improve conductivity. It comes with several venting holes at top side for battery safety. The mod is powered by 1 x 18650 / 20700 battery (not included).This item also has many color to choose. This mod comes with smooth tube. HK25 Diamond Knurl Hybrid Mechanical Mod Clone $14.99 The AV HK Diamond Knurl mod Clone comes with 25mm battery tube. It features simple design with a fixed 510 hybrid top to improve conductivity. It comes with several venting holes at top side for battery safety. The mod is powered by 1 x 18650 / 20700 battery (not included).This item also has many color to choose. This mod comes with diamond knurled tube. Original Snowwolf 200W Plus TC VW Variable Wattage Box Mod $45.99 The Original SnowWolf 200W Plus is constructed from zinc alloy and powered by 2 x 18650 batteries (not included). The Snow Wolf Plus 235W supports wattage adjustable from 10W to 235W. The mod is with multiple protections for safe to use. Original Advken Manta RTA Rebuildable Tank Atomizer Original Price $39.99,Now Only $26.99 Please log in to see the lower price. Introducing the new RTA from Advken, the Manta RTA is a 24mm diameter tank with 4.5ml capacity (3ml with spare tank sleeve). The special two-post design can be compatible with different types of wires. It also features convenient top filling, gold plated posts, and bottom adjustable airflow. Manta RTA comes with a PEI 810 wide bore drip tip.This item also has many color to choose. Original CoilART Azeroth Squonk Mechanical Box Mod + DPRO RDA Kit Original Price $99.99,Now Only $55.29 Please log in to see the lower price. The authentic CoilART Azeroth Squonk Kit consists of CoilART Azeroth box mod and CoilART DPRO RDA.This item also has many color to choose. Mod: The Authentic CoilART Azeroth Squonk Mod comes with attracting appearance: aluminium anodizing body with Ultem fire button and carbon fiber plate. It is a nice squonk mod with 7ml food grade silicone bottle. The Azeroth Squonk Mod is compatible with 18650, 20700 and 21700 battery (not included). RDA: The Stylish DPRO RDA from CoilART is a 24mm diameter RDA with creative postless deck. The length extended airflow system creates awesome flavor. The build deck features 24K gold plated postless deck with 3mm juice well. It is easy for both single coil and dual coil. The Goon style ultem drip tip has inner groove, which can prevent e-juice coming from the bottom to mouth. The RDA comes with bottom feeder pin. 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.99 The 810 drip tip is made from PEI with 13.5mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. Original Vapjoy 810 Replacement Drip Tip for 528 Goon / Kennedy / Reload RDA $3.99 The Original Vapjoy 810 drip tip is made from brass with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This product comes with one piece (1 PC). Original GeekVape 6 in 1 Coil Pack for DIY Rebuilding Original Price $12.80,Now Only $9.99 The Original GeekVape 6 in 1 Coil Pack consists of 2 x Alien Coils (single 0.37ohm / dual 0.18ohm), 2 x Alpha Braid Coils (single 0.32ohm / dual 0.16ohm), 4 x Fused Clapton Coils (single 0.38ohm / dual 0.19ohm), 2 x Clapton Helix Coils (single 0.36ohm / dual 0.18ohm), 2 x Clapception Coil (Single 0.58ohm / dual 0.28ohm), 2 x Tidal Coil (single 0.52ohm / dual 0.26ohm). This product comes with totally 20 PCS of coils in 1 pack. |
22.12.2017, 04:40 | 13 |
Driptech-TS Goon Box Mechanical Squonk Box Mod Clone $23.99
The Driptech-TS Goon Box Mechanical Squonk Box Mod Clone is more powerful than Driptech-DS as it uses triple 18650 batteries in parallel (not included). Constructed from aluminum and with ergonomic design, it feels smooth in hand. The soft silicone squonk bottle can hold 8ml of e-juice. YFTK Le Supersonic RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99 The YFTK Le Supersonic BF RDA Clone is constructed from 316 stainless steel in 24mm diameter. The build deck is wide and comes with dual post for single or dual coil building. The airflow is adjustable with the airslots on the cap, and there are three airholes on each side for your favorite configuration. This RDA comes with bottom feeder pin. Original Aleader Funky Squonk Mechanical Box Mod + BF RDA Kit Original Price $68.80,Now Only $30.99 The Original Aleader Funky Squonk Resin Kit consists of Aleader Funky Squonk Box Mod and Aleader Funky RDA. Mod: The Aleader Funky Squonk Box Mod features colorful resin body with oversized stainless steel fire button. With spring loaded 510 connector, it can support most BF RDA. Take off the flip-style back panel, there is a 7ml silicone squonk bottle inside the mod. Powered by single 18650 battery (not included), the mod can provide full power and nice squonking experience for you. RDA: The Aleader Funky BF RDA is a 24mm atty with colorful resin cap, which matches the Funky Squonk Box Mod very well. It comes with deep juice well to storage more e-juice and the side airflow will brings smooth and massive vapor. Driptech-TS Goon Box Mechanical Squonk Box Mod Clone + Goon 1.5 RDA Clone Kit $28.99 The Driptech-TS Goon Box Squonker Clone Kit consists of Driptech-TS Goon Box Squonk Box Mod Clone and Goon 1.5 RDA Clone. Mod: The Driptech-TS Goon Box Mechanical Squonk Box Mod Clone is more powerful than Driptech-DS as it uses triple 18650 batteries in parallel (not included). Constructed from aluminum and with ergonomic design, it feels smooth in hand. The soft silicone squonk bottle can hold 8ml of e-juice. RDA: The Goon 1.5 RDA Clone is constructed from aluminum cap with a stainless steel base. It measures 24mm in diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control. The RDA comes with an 810 wide bore drip tip. |
25.12.2017, 04:58 | 14 |
NarCa RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.59
The Narca RDA Clone is constructed from stainless steel in 22mm diameter. The deck features dual post design for single coil building. The airflow is adjustable with the airslots on the cap. PEI heat resistant drip tip is included. This RDA comes with bottom feeder pin. Original Oumier VLS RDA Rebuildable Dripping Atomizer with BF Pin Original Price $27.99,Now Only $17.99 The Original Oumier VLS RDA is constructed from PC and stainless steel with 25mm outer diameter. The separately deck is with dual-pole quad-hole to support vertical coil / transverse coil and single coil / dual coil building. The VLS RDA supports five-hole side airflow and comes with BF pin for bottom feeder. Supreme PVC Wrapper Skin Sticker for 18650 Battery $1.49 The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. This product comes with 10 PCS in one pack. Replacement Tank Tube Sleeve for Reload RTA Clone $3.99 The replacement tank tube is made from resin and is suitable for Reload RTA Clone. This product will be shipped by random color (one piece). The atomizer on the image is for reference only, not included. Replacement Tank Tube Sleeve for Advken Manta RTA $3.99 The replacement tank tube is made from resin and is suitable for Authentic Advken Manta RTA. This product will be shipped by random color (one piece). |
26.12.2017, 04:40 | 15 |
Original OBS Bat 218W TC VW Variable Wattage Box Mod $69.00
The Original OBS Bat Mod features unique appearance, ergonomic design, customizable LED lights, multiple protections and powerful output. There are 7 colors for you to choose for the LED light. Powered by dual 18650 batteries (not included), the Bat Mod can deliver power up to 218W. Bat Mod supports atomizer resistance from 0.1 to 2ohm.This item also has many color to choose. Original Innokin BigBox Atlas 200W TC VW Variable Wattage Box Mod $56.99 The Original Innokin BigBox Atlas 200W Box Mod features full resin body with unique honeycomb design, which is colorful and stylish. Powered by dual 18650 batteries (not included), the mod is capable of outputting up to 200W. Temperature control suite is also available. The fire button comes with special engraved pattern. With the ultra compact size and powerful performance, the Innokin BigBox Atlas 200W Box Mod will bring you different vaping experience.This item also has many color to choose. Coppervape NarCa RDA Rebuildable Dripping Atomizer Clone with BF Pin $11.59 The Coppervape NarCa RDA Clone is a 22mm atty with fine finish and beloved appearance. Constructed from PEI (cap) and 316 stainless steel (base), its deck features dual post with large screws for easy building and gold plated positive pin for high conductivity. The airflow gets into the chamber via dual airslots and hits the side of coil directly, giving you great flavor and vapor production. 510 Ultem drip tip is included. This RDA comes with bottom feeder pin.This item also has many color to choose. Kindbright DNV Scar Atty RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $12.99 The Kindbright DNV Scar Atty RDTA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single or dual coil building. The side airflow is adjustable for smooth vapor. Removable POM wide bore drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Reload V1.5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99 The Reload V1.5 RDA Clone is constructed from stainless steel in 24mm diameter. It features quad posts large build deck for both single and dual coil building. The bottom airslot can be adjusted to single or dual for different coil configuration. Gold plated provides great conductivity. POM drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Original YC Vape Siphon Juice Tank Adapter for 18mm / 22mm / 24mm BF RDA / RTA $10.99 The Original YC Vape Juice Tank Adapter is an innovative Siphon accessory used on bottom feeder RDA / RTA. It is a 24mm adapter and can compatible with atomizers not over 24mm. With this adapter, it allows your BF RDA / RTA to work well on a non-squonk device and hold extra 4ml of e-juice. It is suitable for those who have bottom feeder atomizers but are not willing to buy a squonk device.This item also has many color to choose. Original OBS Bat 218W TC VW Variable Wattage Box Mod + Damo Tank Kit $99.00 The Original OBS Bat Kit consists of OBS Bat Mod and OBS Damo Sub Ohm Tank.This item also has many color to choose. Mod: The Original OBS Bat Mod features unique appearance, ergonomic design, customizable LED lights, multiple protections and powerful output. There are 7 colors for you to choose for the LED light. Powered by dual 18650 batteries (not included), the Bat Mod can deliver power up to 218W. Bat Mod supports atomizer resistance from 0.1 to 2ohm. Tank: The Original OBS Damo Tank is a 25mm sub ohm tank that features 5ml large capacity, easy top filling with hidden side filling hole, narrow chimney and beveled drip tip for dense vapor, and wide airslots for bottom airflow, which is adjustable. There are two options for the coil: the 0.4ohm M2 coil rated for 30~50W, the 0.2ohm M6 coil rated for 40~100W. |
27.12.2017, 04:30 | 16 |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Original Augvape V200W TC VW Variable Wattage Box Mod Original Price $69.99,Now Only $47.99
Inspired by a classic and revolutionary car engine B18C, the Original Augvape V200 Mod is the first device adopts this attractive design. The mod is a compact 200W device with hidden buttons design, which feels good in the hand. V200 keeps the car engine elements such as Wheel Hub being 510 connector and Oil Filling Cover being rotation button to adjust wattage. There are 3 output modes, the Normal, Bypass, V mode. This mod is powered by dual 18650 batteries (not included) and supports atomizer resistance from 0.05 to 3ohm.This item also has many color to choose. Original Tesla Colt Mini 80W 2000mAh TC VW Box Mod $43.99 The Tesla Colt Mini Box Mod is a compact device with built-in 2000mAh Lithium battery and stable performance at between 7 to 80W. There are various modes for your choice, and the taste mode is easy to use by selecting among Norm, Soft, Hard and User. Colt Mini supports atomizer resistance from 0.1 to 3ohm in power mode, and 0.05 to 1ohm in temperature control mode.This item also has many color to choose. Original Digiflavor DROP RDA Rebuildable Dripping Atomizer with BF Pin Original Price $36.00,Now Only $22.99 Please log in to see the lower price.Digiflavor introduces a new dripper for flavor chaser. The Original Digiflavor DROP RDA is a 24mm diameter atomizer that provides smooth vaping experience. The dual post build deck comes with 4 larger post holes allowing for easy coil placement, and maximum build space with open access to trim excess. And the Locking top cap guarantees perfect airflow positioning which makes adjusting airflow much easier. Two kinds of 810 drip tips are included, as well as a 510 drip tip adapter. DROP RDA can be used as a standard dripper or a squonk-friendly one.This item also has many color to choose. This RDA comes with bottom feeder pin. SXK Le Supersonic RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90,Now Only $12.99 The SXK Le Supersonic BF RDA Clone is constructed from 316 stainless steel in 24mm diameter. The build deck is wide and comes with dual post for single or dual coil building. The airflow is adjustable with the airslots on the cap, and there are three airholes on each side for your favorite configuration. This RDA comes with bottom feeder pin. Tower Mods Desolator Hybrid Mecahnical Mod Clone + Axis RDA Clone Kit $18.99 The mod kit consists of Tower Mods Desolator Mecahnical Mod Clone and Axis RDA Clone.This item also has many color to choose. Mod: The Tower Mods Desolator Mecahnical Mod Clone is constructed from brass with hybrid connection. The mod features artistic patterns almost on the whole tube, brass connection for better conductivity and magnetic fire button. The mod is powered by single 18650 battery (not included). RDA: The Axis RDA Clone is constructed from brass (cap) and stainless steel (base) in 24mm diameter. The build deck features triple post design, T shaped center post for easy building and 8mm deep juice well for juice storage. The airflow can be adjusted with multiple airflow configuration, from zero to maximum (5 holes open). Heat resistant Ultem wide bore drip tip is included. Original Tesla Colt Mini 80W 2000mAh TC VW Box Mod + H8 Mini Tank Kit $52.79 The Original Tesla Colt Mini Kit is comprised of Tesla Colt Mini Box Mod and H8 Mini Tank.This item also has many color to choose. Mod: The Tesla Colt Mini Box Mod is a compact device with built-in 2000mAh Lithium battery and stable performance at between 7 to 80W. There are various modes for your choice, and the taste mode is easy to use by selecting among Norm, Soft, Hard and User. Colt Mini supports atomizer resistance from 0.1 to 3ohm in power mode, and 0.05 to 1ohm in temperature control mode. Tank: The Tesla H8 Mini Tank features 2ml e-juice capacity, slide top filling and bottom airflow for smooth vapor and pure flavor. With the Colt Mini Box Mod, the tank will give you excellent vaping experience. Original Advken Replacement Tank Tube for Manta RTA $4.99 The replacement tank tube is made from PEI and is suitable for Original Advken Manta RTA. This product comes with one piece of PEI tube. |
28.12.2017, 04:55 | 17 |
Re: 3FVape - New products & Deals Update
Original Aleader Funky 160W TC VW Variable Wattage Box Mod $46.99
The Original Aleader Funky 160W box mod has beautiful interchangeable stable wood plates to satisfy your need to customize. Powered by 2 x 18650 batteries (not included), the output wattage can reach maximum 160W. The Funky 160W features a water resistant OLED display screen. Three power modes available: Soft, Standard, and Powerful. This mod allows you to go from 5 to 99.9W in 0.1W increments; when you go above 100W, the wattage increases in 1W increments all the way up to 160W. This mod also features 2A onboard charging for extra convenience.This item also has many color to choose. The stabilized wood plate is in random color. Driptech DS Mechanical Squonk Box Mod Clone $19.99 The Driptech-DS Goon Box Squonk Mod Clone features aluminum body with ergonomic design, which feels good in hands and is very lightweight. It comes with a 8ml silicone bottle for squonking. Powered by dual 18650 batteries (parallel, not included), this mod will provide raw power for massive clouds.This item also has many color to choose. Original YouDe UD Apro 24 Sub Ohm Tank Clearomizer $23.99 The Original YouDe UD Apro 24 Tank is a 24mm sub ohm tank with 2ml e-juice capacity. The tank features retractable top fill design, stealth airflow inlet, plug-pull mesh organic cotton coil for easy replacement, and innovative base design, which can collect and lock condensation to avoid leaking out.This item also has many color to choose. Driptech DS Mechanical Squonk Box Mod Clone + Goon 1.5 RDA Clone Kit $24.99 The Driptech DS Goon Box Squonker Clone Kit consists of Driptech-DS Goon Box Squonk Box Mod Clone and Goon 1.5 RDA Clone.This item also has many color to choose. Mod: The Driptech-DS Goon Box Squonk Mod Clone features aluminum body with ergonomic design, which feels good in hands and is very lightweight. It comes with a 8ml silicone bottle for squonking. Powered by dual 18650 batteries (parallel, not included), this mod will provide raw power for massive clouds. RDA: The Goon 1.5 RDA Clone is constructed from aluminum cap with a stainless steel base. It measures 24mm in diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control. The RDA comes with an 810 wide bore drip tip. |
29.12.2017, 05:15 | 18 |
Original Pioneer4You IPV Xyanide 200W TC VW Variable Wattage Box Mod Original Price $99.99,Now Only $50.99
Please log in to see the lower price. The Original Pioneer4You IPV Xyanide Mod features attracting appearance and powerful chipset. IPV Xyanide adopts YiHi SX-460 Chip which is capable of delivering output power from 5W to 200W. The mod also comes with Joules mode and temperature control mode. It is powered by dual 18650 batteries (not included).This item also has many color to choose. Redemption RDA Rebuildable Dripping Atomizer Clone $8.59 The Redemption RDA Clone is a 24mm rebuildable atomizer constructed from stainless steel. It features Rapture style posts and Apocalypse style airflow with single airflow option. The dual clamp posts forms a bridge over the shelf for extra space. POM drip tip is included.This item also has many color to choose. Atty OLC RDTA Rebuildable Dripping Tank Atomizer Clone $9.89 The Atty OLC RDTA Clone is a 22mm rebuildable tank constructed from 316 stainless steel. The RDTA features top fill port for convenient refilling, 2ml e-juice capacity, dual post design for single coil building and 5 airholes in different size to meet different airflow configuration. POM drip tip is included.This item also has many color to choose. Kindbright Hussar RDA V1.0 Rebuildable Dripping Atomizer Clone with BF Pin $10.99 The Kindbright Hussar RDA V1.0 Clone is constructed from 316 stainless steel in 22mm diameter. The deck features postless design for single coil building. The side airflow is adjustable with dual airholes for smooth vapor. Removable POM drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. Battlefield Hybrid Mechanical Mod Clone + Battle RDA Clone Kit $22.99 The Battlefield Battle Field mod Clone kit consists of Battlefield Mechanical Mod Clone and Battle RDA Clone.This item also has many color to choose. Mod: The Battlefield Mechanical Mod Clone is made from brass and powered by 1 x 18650 battery (not included). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 4 vent holes on the top of the Battlefield mod. The mod is powered by single 18650 battery (not included). RDA: The Complyfe Battle RDA Clone is constructed from stainless steel dual-post deck, brass top cap and stainless steel drip tip. The post holes and flathead screws are large for easy building. The cap has dual airslots for side airflow. Barebones Hybrid Mechanical Mod Clone + Unholy V2 RDA Clone Kit $19.99 The Barebones Mod Clone Kit consists of Barebones Mech Mod Clone and Unholy V2 RDA Clone.This item also has many color to choose. Mod: The Barebones Mechanical Mod Clone is a sleek 25mm tube mod constructed from stainless steel. It features spring fire button, copper battery contact for great conductivity, bottom venting holes and artistic engraved pattern. Most importantly, this mod can be powered by single 18650 or 20700 battery (not included). RDA: The Unholy V2 RDA Clone is a 25mm rebuildable atomizer constructed from stainless steel. The deck features dual post design and super large post holes for easy building. The cap has dual airslots for adjustable side airflow. PEI drip tip is included. AV Gyre Dimple Hybrid Mechanical Mod Clone + Headshot RDA Clone Kit $22.99 The AV Gyre Dimple Mod Clone Kit consists of AV Gyre Dimple Mech Mod Clone and Headshot RDA Clone.This item also has many color to choose. Mod: The AV Gyre Dimple Hybrid Mechanical Mod Clone is constructed from aluminum. The Fast Twist mechanical mod clone is powered by 1 x 18650 battery (not included). Comes with the unique twisted shape, this Fast Twist style mod will bring an amazing vaping experience to your vaping life! RDA: The Headshot RDA Clone is constructed from stainless steel (cap) and brass (base) in 24mm diameter. The build deck has a T-clamp positive post and dual negative post, which allows you to DIY various types of coils. The side airflow hits the coil directly without any adjustable mechanism. Please Note: The brass base is without anti-oxidation process, please don't touch it with hands directly. 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $1.99 The replacement 510 drip tip is made from resin with 12.5mm height. It is suitable for all atomizers that fit 510 drip tip.This item also has many color to choose. Replacement Wide Bore Drip Tip for PTI RTA Clone $1.99 The replacement wide bore drip tip is made from resin with 12mm height. It is suitable for PTI RTA Clone.This item also has many color to choose. The connector of the drip tip is about 13.8mm in diameter. Please make sure this fits your atomizer before purchase. Original Vapethink Magic Shark MS Bag for E-cigarette $10.99 The Original Vapethink Magic Shark MS Bag features large content for storing e-cigarette mods, atomizers, accessories and vape tools. It measures 145mm by 175mm by 40mm. With this bag, there is no need to worry the placement of your e-cig device and tools. This MS Bag is M size.This item also has a L size version to choose. |
30.12.2017, 04:51 | 19 |
Original GTRS P222 222W TC VW Variable Wattage Box Mod $58.99
The Original GTRS P222 Box Mod is a versatile temperature control and variable wattage mod. Powered by dual 18650 batteries (not included), this mod is able to deliver output power up to 222W, which will bring you extreme vaping experience.This item also has many color to choose. Original Vandy Vape Maze Sub Ohm BF RDA Rebuildable Dripping Atomzier $29.90 The Original Vandy Vape Maze Sub Ohm BF RDA can be regarded as the first Sub Ohm BF RDA in the world. Maze Sub Ohm BF RDA adopts Maze Coils, which is so innovative that can compatible with the Regulated and Mechanical Mod, bringing better safety and compatibility. With the five different airflow direction and Maze Coils, it will prevent spit-back of juice and deliver the ultra smooth experience.This item also has many color to choose. This RDA comes with bottom feeder pin. Original IJOY Capo 216W Squonk Box Mod + SRDA Kit $67.99 The IJOY CAPO 216 Kit consists of IJOY CAPO 216W Squonk Mod and IJOY SRDA.This item also has many color to choose. Mod: The Original IJOY CAPO 216 Box Mod is a powerful squonker, which is powered by dual 20700 batteries (not included) and can reach maximum power to 216W. It comes with a large display screen and side venting holes for ventilation. RDA: The Original IJOY COMBO SRDA is the first RDA using pre-made coil, which is a subversive innovation of RDA, with revolutionary significance. There is no need to build coils by yourself. The COMBO SRDA can be disassembled, cleaned and replace the cotton with special wrench equipped to achieve the purpose of repeated use. The side airflow control is adjustable to provide cloudy vapor. It comes with wide bore 810 ultem drip tip, which is dripping compatible. This RDA comes with bottom feeder pin. |
30.12.2017, 15:16 | 20 |
Запретить полностью! Даёшь здоровый образ жизни!
РШ (30.12.2017)
