Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Войти через OpenID
  • Бесплатные розыгрыши призов
  • Для гостей форума
  • Пожертвования (Donate)
  • Реклама на форуме
Просмотров в теме 3639   Ответов в теме 12   Подписчиков на тему 3   Добавили в закладки 0
Старый 11.10.2015, 18:24 Автор темы   1
Модератор своих разделов
Аватар для HKJ
Последняя активность: Сегодня 09:32
Поблагодарили: 2414 раз(а) в 791 сообщениях
По умолчанию Test/Review of Charger Keeppower L1
Keeppower is known for its LiIon batteries, but now they have also made a charger. It is a single cell charger with two charge currents and can handle sizes up to 26650, the charger is powered from usb.
I got the charger in a cardboard retail box with fairly limited printing on.
The box contained the charger, a bag and a usb cable, there was no instruction sheet.
The bag is for the charger and the cable.
The micro usb connector is placed on the front, just below the display.
The user interface is a display and a single button.
A press on the button will change between 500mA and 1000mA charge current, but only when there is a battery in the charger.
Holding the button down will turn off the display and disable the current change function, the charger will continue to charge with selected current. To turn display on again the button must be held down again.
The display has an animated battery icon, charge percent, voltage and selected current.
The charge uses the typical slider construction with a metal rail and it works smoothly from about 29.5mm to 71.5mm, i.e. the charger can handle any 18650 and 26650 cells both protected and unprotected.
The charger can easily handle 71 mm long batteries, including flat top cells.
Measurements
  • Below 1 volt the charger will not detect a battery and the current will be zero, this means that it cannot reset protection circuits.
  • Between 1.0 and 1.8 volt the charger will show empty battery with 0.00 volt, no charge current is applied.
  • Between 1.8 volt and 3.0 volt the charger will charge with about 100mA at 500mA setting and 200mA at 1000mA setting.
  • Above 3.0 volt the charger will use regular charging.
  • The charger will not restart if battery voltage drops.
  • Charge will restart charging after power loss, or battery insertion.
  • Voltmeter works from 1.8 volt to about 4.3 volt and is within 0.03 volt. It will continue to update when charging is finished.
  • When charging is finished the charger will discharge the battery with about 20uA.
  • When charger is without power it discharge the battery with about 40uA.
The voltage scale on my charts is increased to 4.35 volt, because this charger over charges
At first glance this looks like a good CC/CV charge curve with 100mA termination, but there is one serious problem: The charger do not charge to 4.20 volt, but to 4.30 volt.
At 500mA charge current the problem is exactly the same.
The two other cells works the same way with CC/CV and over charge.
The charger has no problems with the older cell.
It looks like there is some small problems with the charging at 500mA for this cell. Due to this the end result is slightly better.
M1: 29,4°C, M2: 39,2°C, M3: 40,6°C, HS1: 45,3°C
The battery stays cool in this charger.
M1: 28,8°C, M2: 40,8°C, M3: 43,6°C, HS1: 44,1°C
The charger needs about 5 second to start.
The charger current can be switched at any time during charge (if the display is on).
Conclusion
The charger looks nice for a single cell charger and with two current settings it can handle most cell sizes, but the higher voltage makes it nearly useless (There is a few 4.3 volt batteries on the market).
Generally I will not recommend this charger, but if you have some 4.3 volt cells it can be very useful (Just remember to mark the charger clearly).
If Keeppower fixes the over charge and makes some way to recognize fixed chargers, it will be a good charger.
Notes
Using this charger will not make quality batteries explode, but it will reduce the lifetime of the batteries significantly.
Here is an explanation on how I did the above charge curves: How do I test a charger
Поблагодарили: 8 раз(а)
Fast (23.10.2015), fnksb (11.11.2015), ko54 (11.10.2015), Qwertus (11.10.2015), vorsmann (23.10.2015), Vyacheslav Demeshko (14.10.2015), Waryag (18.02.2016), Сумской (11.10.2015)
Реклама на форуме.
Разместить рекламу
Старый 11.10.2015, 18:33   2
Последняя активность: Сегодня 14:47
Сказал(а) спасибо: 548
Поблагодарили: 6930 раз(а) в 3980 сообщениях
По умолчанию Re: Test/Review of Charger Keeppower L1
Хрень какая-то.
С фонарями лажанулись, с зарядкой лажанулись...
Qwertus на форуме   Ответить с цитированием Вверх
Старый 23.10.2015, 14:50   3
Сумской
KEEPPOWER УКРАИНА
Аватар для Сумской
Последняя активность: Сегодня 14:28
Сказал(а) спасибо: 312
Поблагодарили: 513 раз(а) в 335 сообщениях
Продублирую ответ от Keeppower:
Dear Henrik, Wish all the best! Just review your test report of our charger L1( Thanks you very much. Nice test as usual. I think the sample you tested should be our Engineering Sample, we set of with charge to 4.30V, 4.25V for testing. It is not our finial products. We now are under amending; we will set with cut-off at 4.20V and with 0V re-setting function. We also finish 2 slots L2 LCD charger; we will send official samples to you sooner.
Сумской на форуме   Ответить с цитированием Вверх
Старый 23.10.2015, 14:57   4
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Последняя активность: Вчера 12:49
Сказал(а) спасибо: 3395
Поблагодарили: 618 раз(а) в 475 сообщениях
In Fino verytas
Старый 23.10.2015, 18:12 Автор темы   5
HKJ
Аватар для HKJ
Посмотреть сообщение Сообщение от Сумской :
I will not call it an Engineering sample, because I bought it in an ordinary webshop. It might be a test production or null production, but it cannot really be an Engineering sample.
I will be happy to test a fixed version of it and a 2 slot version. I will recommend adding some identification to the fixed version.
Старый 23.10.2015, 18:47   6
Vladimir0vi4
Аватар для Vladimir0vi4
Последняя активность: 29.03.2018 21:10
Сказал(а) спасибо: 1321
Поблагодарили: 403 раз(а) в 280 сообщениях
Great review, thank You HKJ.
Да что же они штампуют эти айфоны зарядки пачками, но заряжать по выбору до 4.2В или 4.35В могут единицы...
Vladimir0vi4 вне форума   Ответить с цитированием Вверх
Старый 24.10.2015, 16:05   7
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
ревью то хорошее а зарядка так себе.
Старый 11.11.2015, 08:22   8
Merlin
Аватар для Merlin
Последняя активность: Сегодня 13:43
Сказал(а) спасибо: 373
Поблагодарили: 181 раз(а) в 101 сообщениях
Господа! Подскажите пожалуйста, можно ли использовать данное устройство если оно заряжает до 4.27 вольта? Мне попалось такое и я опасаюсь вредных последствий. Из примерно 20 зарядок, которые у меня были, самое большое значение напряжения, которого они добивались, было 4.21 вольт. Чаще всего мне попадались зарядки заряжающие до 4.18 - 4.19 вольт.
Merlin вне форума   Ответить с цитированием Вверх
Старый 11.11.2015, 08:35   9
andyz
старожил
Аватар для andyz
Последняя активность: 15.06.2018 20:04
Сказал(а) спасибо: 654
Поблагодарили: 1185 раз(а) в 644 сообщениях
Посмотреть сообщение Сообщение от Merlin :
Использовать можно, но нежелательно, если не хотите сократить жизнь АКБ.
Околофонарные мелочи
Merlin (11.11.2015)
Старый 11.11.2015, 09:26   10
Merlin
Аватар для Merlin
Спасибо! А на сколько думаете сократится жизнь АКБ при постоянном использовании зарядки заряжающей до 4.27 вольта? Что уменьшится, количество циклов или срок использования АКБ? Мне для счастья надо 100 циклов и 3 года жизни (хорошо бы емкость сохранилась при этом процентов на 70. Зарядок полно, но эта очень нравится.
Похожие темы
Test/Review of Charger Energizer Intelligent Charger CHP42EU HKJ Battery chargers. Reviews and tests. 3 22.07.2015 11:01
Test/Review of Charger Energizer Maxi Compact Charger HKJ Battery chargers. Reviews and tests. 0 20.05.2015 21:04
Test/Review of Keeppower IMR18650 2250mA (Black) HKJ Batteries and Chargers. Reviews and tests. 0 23.07.2012 21:53
Test/Review of Keeppower 18650 2900mAh (Black) HKJ Batteries and Chargers. Reviews and tests. 0 01.04.2012 19:02
Test/Review of Keeppower 18650 3100mAh (Black) HKJ Batteries and Chargers. Reviews and tests. 0 31.03.2012 19:20
Ваши права в разделе
Вы не можете отвечать в темах
BB коды Вкл.
Смайлы Вкл.
[IMG] код Вкл.
HTML код Выкл.
Быстрый переход
Текущее время: 15:15. Часовой пояс GMT +3.
Даты в формате dd.mm.yyyy.
Powered by vBulletin® 3.8.x
Список наших проектов:
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©2007 - 2015, FONAREVKA.RU.
Время генерации страницы 0.27387 секунды с 22 запросами
