4038 0 1 0 |
28.09.2015, 18:17 | 1 |
Регистрация: 01.08.2011 Последняя активность: 09.06.2017 16:17 Адрес: South Korea
Сказал(а) спасибо: 4
Поблагодарили: 401 раз(а) в 86 сообщениях
Acebeam T20 Thrower (XP-L HI NW, 1x18650/2xCR123A, 2x18650/4xCR123A) Review
Acebeam has released their XP-L HI throwing light, the T20. The light runs on 2x18650 or 4xCR123A with an extender.
. . Packaging is the same as Acebeam T25 I reviewed. Inside the nice cardboard box, everything is firmly secured in cut-out foam. You will find the light with belt holster, two spare o-rings, tailcap rubber button cap, lanyard, manual and warranty card. . . Manufacturer Specifications from Acebeam website & manual : • Cree XP-L high intensity LED with lifespan 20yrs of runtimes • Max 1500 lumens output (2x18650) • Output - Level 1 : 0.5lm - Level 2 : 50lm - Level 4 : 300lm - Level 5 : 700lm - Level 6 : 1,500lm - Strobe : 1,500lm • Working voltage : 3v~12v • Max. Runtime : 1,200hrs • Max beam : 1,050 meters • Peak beam intensity : 275,500cd • Aircraft grade aluminum body structure • Premium Type III hard anodized anti-abrasive finish • Ultra-clear tempered glass lens with anti-reflective coating • Momentary forward click tactical switch • Strobe mode for tactical and emergency use • Smooth reflector for max. light output • Highly focus beam for maximum distance • Tactical knurling for firm grip • Streamlined body design • Electronic reversed polarity protected design • Intelligent high efficient circuit for max. performance and runtime • Intelligent temperature controlled light output for safety • Impact resistant : 1.2meters • Waterproof : IPX-8 Standard (2meters) • Size : 251mm(length)×70mm(head)×25.4mm(tube) • Weight : 290g • Battery : 4×CR123A or 2×18650 Note : The above data has been measured in accordance with the international flashlight testing standards ANSI/NEMA FL 1 using the Acebeam battery (two LG HE2 2500mAh 18650) under laboratory conditions. The data may vary during real-world use due to battery type, individual usage habits and environmental factors. . . The overall shape and design is similar to the T25, with a smaller head, body tube and tailcap. The hard (type III) anodizing is a matt black and consistent throughout with no chips or blemishes to be found on my sample. Labels are minimal, but clear in bright white against the black background. There is knurling on the 2x18650 extender tube only. There is nothing on the body works as an anti-roll device. But if you attach the lanyard came with the light, it will help a little to prevent rolling. . . The light comes apart into four parts (i.e. head, two battery tubes and tailcap) without the use of tools. . . The light has a shallow crenellated stainless steel bezel ring, but not being removable on my sample. The T20 has a number of raised concentric rings near the head of the light to help with grip and heat dissipation. There is a spring in the head, however true flat-top 18650 unprotected cells don't work, due to the longer battery tube. Note that you should use longer button-top 18650 cells. The light has a low voltage warning indication (i.e., it will flash about 3 times every 10 secs when the batteries voltage is 6V for 2x18650's). If you use 1x18650, the light will flash at 3V. The light does have electronic reverse polarity protection function to protect from improper battery installation. . . The light uses ultra-clear tempered AR coating lens. The purple hue is reflected on it. The reflector is clean smooth type. Its surface finish is good from visual inspection, and well-centered XP-L HI V2 LED sits at the bottom of the reflector cup. The reflector is large and deep. This should translate into good throw. According to Cree, the XLamp XP-L High Intensity (HI) LED is the first of Cree’s new class of High Intensity (HI) LEDs optimized to deliver maximum candela through secondary optics. Built on Cree's breakthrough SC5 Technology™Platform, the XP-L HI LED delivers 120 percent more candela than the XP-L HD LED through the same optic. You can see the Cree XP-L specification sheet for more information. Acebeam claims that they used XP-L HI (V2) 4000K for the T25. . . The distinctive aspect of the light is the dual-side switch in the head to control the light. These switches are electronic switches, and control the output levels of the light when on (by a tailcap switch). Note that strobe can be activated directly when on by pressing the upper switch. The switch cap is slightly protruded from a metal surround, but quite set lower position than the head. The switch cap seems silicone rubber. The switch has a good feel to touch and has typical travel, which produces a clear and audible clicking sound when pressed. Scroll down for an explanation of the user interface. . . The battery tube has a cylindrical tube design and you can run 2x18650's or 4xCR123A's with the battery extender. The 1x18650 battery tube has six longitudinal deep grooves, and 2x18650 extender is mostly covered with knurling. The knurling is somewhat aggressive. Grip is good. The wall thickness (3.1mm) of the battery tube seems quite thick. As described above, I recommend you stick with button-top protected 18650 cells (small and large button top both worked fine in my testing). . . The threads at each end are well machined, with those at ends of the battery tube being anodized which allow the light to be locked-out when the tailcap is slightly loosened. All connection ends are fully anodized as well. The screws threads are good quality square-cut. My sample has a good amount of lube on each end of the tube. Threads on each end of the battery tube mate well with no issues of cross-threading or grinding. . . The T20 has a rubber grip ring and attachment point for lanyard which are all removable. . . The tailcap switch is a forward clicky with good feel. The rubber switch cap does protrude at the tail end. It means the tail switch can be very easy to access, even when you are wearing gloves. The switch has a bit stiff tension with tactile clicking feedback. . . User Interface The light is turned on/off by the forward tail switch (i.e., press for momentary on, click for lock on). Mode switching is controlled by the lower side switch in the head. When On, press and release (i.e., click) the lower mode switch repeatedly to cycle between the five main output levels in the following repeating sequence : Turbo -> High –> Med. –> Low -> Firefly. The light has mode memory. The light will come back on in last output used when connecting/activating the tailcap. Note that you can access the momentary Strobe mode by a press-hold of the upper side switch when on. Just release to turn off Strobe. Thanks to the physical forward tail clicky switch, there's no standby current drain when off. . . From left to right, VicLite 18650(2600mAh) protected, Olight SR52UT (XP-L HI V2), Olight M3XS-UT (Dedomed XP-L), Acebeam T20 (XP-L HI V2), Acebeam T25 (XHP50 J4). . . The light comes with a basic nylon belt holster with a velcro strap on the head. The light fits in the holster head-up. It has a loop allows to carry it in horizontal position for belt. . . T20 is long light with a wide head for this class, as expected from a 2x18650's (or 4xCR123A's) powered light since the batteries are arranged end-to-end. The overall size and weight of the light is reasonable for this class. Overall grip is good. Overall build quality is excellent. . . Measured Dimensions & Weight . . PWM The T20 shows no sign of PWM at any output levels. I do think the light is constant current controlled. I noticed there is no buzzing sound at any levels. . . Runtime The runtime to fall to 10% of its initial output from 30 seconds after the point the light is first turned on (i.e., based on ANSI FL-1) for Turbo is as above graph : On Turbo on 2x18650's, the light steps down after about 5mins, and it enter a period of flat regulation, before flashing for low battery indication. On Turbo, the light is semi-regulated on 1x18650 (i.e., slowly drop in output). You will not be able to notice the drop in output over time in practice. Note that you will get more initial output on good quality high current 18650 cell, as seen. The light gets a little warm on Turbo on 2x18650's at the side switch part after 40secs. After about 3~4mins, a half of the head and side switch part get quickly hot. . . On High, the light maintains perfectly flat regulation for an extended period, before flashing for low battery indication. I make no doubt that flat regulation will be evident on Med., Low and Firefly. Note that there are big blips near the end of the run which are from the low-battery warning function of the light (i.e., the light starts blinking for low battery warning at 6V working voltage on 2x18650's as manufacturer says). The flashing is at a fast rate, about three times every 10 secs. . . The timed stepped-down output from Turbo is much brighter than High. . . The T20 is brighter on Max. than the other lights in the 2x18650 XP-L or XM-L(2) class. Overall output-runtime efficiency seems good for the class. . . Beamshot 1. White door beamshot (about 50cm from the white door) on max. output on 2x18650 (2600mAh) VicLite protected cells - ISO125, F/8.0, 1/25sec, Auto white balance . . - ISO125, F/8.0, 1/100sec, Auto white balance . . - ISO125, F/8.0, 1/800sec, Auto white balance . . - ISO125, F/8.0, 1/2000sec, Auto white balance The light shows a defined narrow hot spot and large spill beam. The hot spot is well focused and a corona surrounds the bright hot spot. The beam profile is very clean. The beam has a fairly nice warm yellow tint as claims. . . This is comparison beamshot between Olight M3XS-UT and Acebeam T20 (about 50cm from the white door) on max. output on 2x18650 (2600mAh) VicLite protected cells. . . The above shows a comparison beamshot between Olight SR52UT and Acebeam T20 (about 50cm from the white door) on max. output on 2x18650 (2600mAh) VicLite protected cells. . . 2. 55m Outdoor Beamshot on max. output on 2x 18650 (2600mAh) VicLite protected cells - ISO125, F/2.8, 1sec, Auto white balance . . . . 3. 85m Outdoor Beamshot on max. output on 2x18650 (2600mAh) VicLite protected cells - ISO125, F/2.8, 1sec, Auto white balance . . . . 4. 120m Outdoor Beamshot on max. output on 2x18650 (2600mAh) VicLite protected cells - ISO100, F/2.8, 1sec, Auto white balance . . . . 5. 390m Outdoor Beamshot on max. output on 2x18650 (2600mAh) VicLite protected cells - ISO125, F/2.8, 1sec, Auto white balance . . The T20 is an outstanding thrower for its class. Like the Olight M3XS-UT, it has a fairly tightly focused hotspot. The T20 stands shoulder to shoulder with it. This is number one stock domeless XP-L HI throwing flashlight I have tested to date. . . The T20 gives you a nice firefly output level. . . Overall Impressions • Build quality is excellent • You can use 1x18650 (or 2xCR123A's), and 2x18650's (or 4xCR123A's) with an extender • Electrical reverse polarity protection function • Secondary Strobe switch on the head (i.e., You can access to Strobe directly) • Firefly mode is available • Low battery warning indication function (i.e., the light blinks about 3 times every 10secs when the working voltage is down to 6V with 2x18650's) • No sign of PWM flickers at any output modes • Good warm yellow tint, and fairly nice beam pattern • No anti-roll indentations on the body • True flat-top 18650 unprotected batteries (due to short length) will not work • Number one stock XP-L HI throwing flashlight I have tested to date (i.e., it's true domeless XP-L HI). Acebeam T20 was supplied by Acebeam for review. |
