4713 2 2 0 |
25.08.2014, 19:40 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of LG 18650 E1 3200mAh (Green)
Official specifications:
This is a high capacity 4.35 volt cell. The cell look very good, the two cells tracks nicely and capacity does not change with load up to the rated current. Test with 4.3 volt charging Using a slightly lower charge voltage reduces the capacity with about 0.15Ah Test with 4.2 volt charging Going down to a normal 4.2 volt charger cost 0.4Ah in capacity. Conclusion These batteries can be interesting to drive led lights due to their slightly higher voltage, but it looks like LG has traded high current ability for capacity compared to the older 3000mAh cell. When looking at Wh, this cell can match a 3400mAh cell, due to the higher voltage. I will call it a very good battery, but a 4.35V charger is needed to really use it. Notes and links The batteries was supplied by Akkuteile.de for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries 4.35 volt chargers: Xtar VP2, Xtar SP1
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 25.08.2014 в 20:55] |
25.08.2014, 20:52 | 2 |
Регистрация: 02.09.2013 Последняя активность: 03.01.2017 23:40 Адрес: Amsterdam
Сказал(а) спасибо: 239
Поблагодарили: 263 раз(а) в 170 сообщениях
Re: Test/Review of LG 18650 E1 3200mAh (Green)
Фонари: ZebraLight SC600w Mk II XM-L2, ZebraLight H602w XM-L2, Sunwayman M11R Sirius Titanium. Велосвет: Nitecore TM26 3800, Philips SafeRide 80, B&M Ixon IQ Premium. Зарядки: LiitoKala lii-100 (2шт). Аккумуляторы: Samsung ICR18650-32A 4,35/3200, Panasonic Eneloop BK-3MCCE/2000, Panasonic Eneloop Pro BK-3HCCE/2550. Powerbank: Xiaomi 10000 mAh. Мультиметры: UNI-T UT81B, UNI-T UT33B. |
25.08.2014, 20:55 | 3 |
