Просмотров в теме 2770   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 26.03.2014, 21:18 Автор темы   1
Модератор своих разделов
Аватар для HKJ
Поблагодарили: 2982 раз(а) в 1024 сообщениях
По умолчанию Test/Review of Keeppower 18500 1500mAh (Black) 2014
Official specifications:
  • Min Capacity: 1400mAh
  • Typical Capacity: 1500mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell ICR18500 made in China
  • In Built Safety Circuitry
  • Maximum capacity and reliability
  • High Discharge Rate (Max 2C)
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Over 300 charge-discharge cycles
Keeppower sells two version of 18500, this one is the cheaper version from DLG.
The battery does very fine up to 3A load, that is 2C and matches the rated 2C maximum discharge. Drawing much more than 3A does not really work.
Conclusion
The performance looks average for 18500 batteries, but they are not designed for high current.
I will call the cells acceptable.
Notes and links
The batteries was supplied by Keeppower for review.
alexsav (30.03.2014), blindnick (26.03.2014), Сумской (27.03.2014)
Время генерации страницы 0.07085 секунды с 15 запросами
