3608 0 2 0 |
03.01.2014, 17:46 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Keeppower 18650 3600mAh (Black) 2014
Official specifications:
This is the next increase in battery capacity, from 3400mAh to 3600mAh, as usual with battery capacity increases it is only an small amount. With my test conditions (Discharge to 2.8 volt), I do not get 200mAh more capacity, more like 100mAh. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. The battery can easily deliver 7A with its 11A protection and, being good cells, the two cells does also track nicely. Conclusion When comparing this battery to the 3400mAh cell, the new battery has slight higher voltage and slightly higher capacity, this is not a revolution in any way, just a small improvement. Being based on a Panasonic cell the battery is, of course, a very good battery. Notes and links The battery was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
