289869 711 75 3 |
04.03.2014, 11:37 | 421 |
Регистрация: 17.02.2014 Последняя активность: 12.02.2022 18:55 Адрес: Спб
Сказал(а) спасибо: 57
Re: Новинки зарядных устройств
спс , дали ссылку на него уже http://lygte-info.dk/review...
09.04.2014, 21:54 | 422 |
Регистрация: 19.11.2011 Последняя активность: 11.03.2024 22:06 Адрес: Москва
Сказал(а) спасибо: 54
Olight Omni-Dok Rechargeable Li-ion NiMH Battery Charger
http://hkequipment.net/?sp=... Features: Charges multiple battery types 4-hour charge time for 18650 cells Batteries are charged independently with smart charging technology to regulate power accordingly Ability to simultaneously and safely charge different types of batteries Dual battery power indicators monitor individual charging status of each battery Overcharge protection when a cell has reached a full charge Automatic eight-hour shut off Notification of improper installation or unsupported batteries Rubber feet on bottom for a non-slip surface grip Compatible batteries: Li-Ion (3.6v or 3.7v): 18650, 17670, 16340 and 14500 NiMH/Ni-CD: AA and AAA Specifications: Power Input: DC12V 1A, supplied by included AC/DC adapter AC/DC adapter input: 100~240VAC 50~60HZ AC/DC adapter output: DC12V 1A 3.78" x 1.22" (96mm x 31mm) Weight: 3.6 oz (102g) |
22.04.2014, 12:31 | 423 |
KEEPPOWER УКРАИНА
Регистрация: 30.03.2013 Последняя активность: 02.03.2022 15:51 Адрес: Сумы
Сказал(а) спасибо: 394
XTAR New Charger WP2H
Below is some features of this new charger. Extended slots to suit any size of your batteries (10440/14500/14650/16340/17670/18350 /18500/18650/18700/22650/25500/26650) Design for suiting different batteries type (termination-voltage of 3.6V or 4.2V or 4.35V!) Adjustable charging currents allow it to either power up your batteries with a prompt-charge, or increase the lifespan of your batteries with a soft-charge (0.25A/0.5A/1.0A). Now it comes with more reliable output with indicating power status . Other XTAR specialties: Three-phase charging method (TC/CC/CV) Activation function for over-discharged batteries High safety & Low risk in design and materials used
Всегда актуальное наличие аккумуляторов Keeppower, LG, Panasonic, Samsung, Sanyo, Sony, зарядных устройств Xtar, Keeppower, MIBOXER, а также фонари - Keeppower Украина |
30.04.2014, 17:15 | 424 |
Регистрация: 16.06.2013 Последняя активность: 20.05.2022 19:12 Адрес: Украина, Донецк
Сказал(а) спасибо: 211
Zebralight: H600Fw MKII, H51c; Fenix: HL21, HL23, LD12 S2, E05 R2; Princeton Tec: Remix; Byte; Convoy: S2 T5-5C; Spark: SG5 CW; Xtar: WK41 Sirius AA; Petzl: Tikka 2, Tikkina 2; Olight: H1 Nova NW |
30.04.2014, 18:03 | 425 |
KEEPPOWER УКРАИНА
02.05.2014, 23:53 | 427 | |
Регистрация: 25.03.2014 Последняя активность: 26.02.2015 19:55
Сказал(а) спасибо: 320
Поблагодарили: 260 раз(а) в 143 сообщениях
03.05.2014, 00:19 | 429 |
happy, куришь паришь?
трол. |
happy (03.05.2014)
03.05.2014, 00:22 | 430 | |
03.05.2014, 01:09 | 431 |
Hoвичёк фонарёвки.
Регистрация: 18.08.2012 Последняя активность: Сегодня 17:29 Адрес: Калуга
Сказал(а) спасибо: 1989
Поблагодарили: 1430 раз(а) в 717 сообщениях
Функция повер банка будет нет? Неизвестно?
........... О, уже нашел - всё таки будет эта функция.
Fenix TK21, UltraFire UF-H6, Триплы C20C, ITP A2 EOS ss, Olight S20 Baton, DQG 18650 II, Niteye JA10, DQG AA, DQG 18650 clicky, С22С. [Исправлено: Rime, 03.05.2014 в 01:12] |
06.05.2014, 15:01 | 433 |
Регистрация: 16.10.2012 Последняя активность: 22.02.2022 02:51 Адрес: Киев, Украина
Сказал(а) спасибо: 687
Поблагодарили: 2977 раз(а) в 1380 сообщениях
14.05.2014, 16:00 | 435 |
Хорошая зарядка? или LittoKala лучше? А такая еще?
[Исправлено: Tankist_20, 14.05.2014 в 16:01] |
14.05.2014, 16:05 | 436 |
Регистрация: 06.03.2013 Последняя активность: Сегодня 17:01 Адрес: Тамбов
Сказал(а) спасибо: 648
Поблагодарили: 1883 раз(а) в 1164 сообщениях
Tankist_20 (14.05.2014)
14.05.2014, 16:14 | 437 |
Еще спрошу, как определить когда можно 2А задавать?
14.05.2014, 16:31 | 438 |
Если для 18650 и толще - когда нужно тогда и задавайте
В принципе, если это не китай с песком, они отлично такой ток переварят. Просто если спешить некуда, лучше давать ток поменьше: это полезнее для аккума, в том числе и из-за нагрева, так как на 2А зарядка заметно греется. Оптимально 1А. |
14.05.2014, 16:40 | 439 | |
HID маньяк
Регистрация: 04.09.2010 Последняя активность: 21.04.2024 17:50 Адрес: Это Питер, детка (с)
Сказал(а) спасибо: 778
Поблагодарили: 2570 раз(а) в 880 сообщениях
Знаете ли, SP2 (которая у меня тоже есть), как то расслабила )) В плане того, что даёт возможность аккумы при необходимости заряжать двумя амперами. Я как то и отвык уже, что нужно долго ждать, пока твои акки зарядятся. Поэтому, хоть микрозарядка была тоже нужна, выжидал таки появления "карлика" с зарядными характеристиками как у SP2, не покупая всем известные аналоги, микрозарядников под одну банку 18650, которые больше 500мА на банку не выдают |
14.05.2014, 16:45 | 440 |
HID маньяк
Ну, AW-шные IMR16340 я заряжаю двумя амперами. По расчётам, 2A зарядного тока на 500мАч ёмкости, должны забиваться за 15 минут.
По факту получается чуть дольше. Но всё равно, очень, очень быстро, по сравнению с другими зарядками. |
