54620 177 19 0 |
25.06.2013, 13:48 | 1 |
Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
Olight S15 Baton
http://www.olightworld.com/...
S15 BATON (S15 for short), specially designed for AA battery (D: 14mm, L: 50mm), is a portable LED tactical flashlight with side switch. As a masterpiece of Olight S series after S10 and S20, S15 is assembled with latest CREE XM-L2 LED, and inherits exquisite appearance and easy operation from its predecessors. Improved structural design and well-chosen circuit can make S15 more suitable for everyday use. Package Details: a) Standard accessories: Flashlight x 1 Lanyard x 1 Spare O-RINGs x 2 Replacer of magnet x 1 User’ manual x 1 b) Optional accessories TW10-W TW10-O EXTENDED TUBE DURACELL AA ALKALINE Filter (white, red, green, blue) Features: a) Aviation grade aluminum body, with anti-scratch type III hard anodizing. b) Stainless steel head ring can bear higher impaction. c) Side switch with blue button cap, soft and comfortable to press. d) Special designed smooth reflector and 99% luminousness lens with anti-reflective coating on both sides make longer beam distance. e) High efficient drive circuit, compatible with any rechargeable and non-rechargeable AA battery; The run time is up to 15 days under moonlight mode. f) Assembled with latest CREE XM-L2 LED, and maximum output up to 280 lumens (tested by using 14500 rechargeable lithium battery). g) Four adjustable brightness level: moonlight-low-middle-high and strobe; automatic memory function can memorize the brightness level while off (excluding strobe). h) With flashlight off, pressing side switch to directly activate high mode or moonlight mode. i) With a long-arm convertible pocket clip for easy access. j) There is a lanyard hole in the tail which can pass through fabric strap with diameter of 2mm. k) with detachable strong magnet inside the tail, the flashlight can be attached vertically to any iron objects. l) Flat bottom allows stable tail standing. m) extremely low standby current: 0.5uA while using 1.5V battery; 1.2uA while using 4.2V battery. n) Battery reverse polarity function guards against improper battery installation. o) Lock-out function p) Waterproof: IPX8 |
25.06.2013, 13:49 | 2 |
Re: Olight S15 Baton
Сайт олайта, кажется, только заполняется.
Однако про этот фонарь мы и так много слышали. [Исправлено: uV3, 25.06.2013 в 13:51] |
25.06.2013, 14:05 | 4 |
читатель
Регистрация: 31.01.2013 Последняя активность: 06.07.2020 23:43 Адрес: Луганск. Украина
Сказал(а) спасибо: 2774
Поблагодарили: 4514 раз(а) в 2498 сообщениях
Если сохранят ценовую политику батонов, вполне вероятно, что фонарик будет успешно продаваться. Как и в случае других батонов, некоторые недостатки будут компенсированы гуманным ценником.
В качестве оффтопа: кто-нибудь юзал S80? [Исправлено: Dali, 25.06.2013 в 14:10] |
25.06.2013, 17:03 | 5 |
Регистрация: 01.03.2012 Последняя активность: 05.08.2017 16:58
Сказал(а) спасибо: 20
Так!! а удлинитель на 2АА где?
LD10!-TK41!-TK-21!-PD32!-Eagletac D25A Clicky!-Eagletac D25LC2 Clicky-Eagletac D25А2 Clicky-Fenix HP20-Fenix E05-ТК22-Tank007 E9-ZebraLight SC52-Olight S10 Baton - ThruNite Ti - Olight S15 Baton |
25.06.2013, 18:35 | 6 |
Hoвичёк фонарёвки.
Регистрация: 18.08.2012 Последняя активность: Сегодня 16:02 Адрес: Калуга
Сказал(а) спасибо: 1989
Поблагодарили: 1430 раз(а) в 717 сообщениях
Хм, а вот этот батон мне нравится.
За счёт того что бат. отсек по диаметру тоньше головной части, весь фонарь смотрится как-то гамоничнее чем S20.
27.06.2013, 02:08 | 7 |
Доступны официальные спецификация и иллюстрации
Olight's newest addition to the massively popular Baton line combines all of the functionality and power of previous Batons with a widely available and economical AA power source. The S series is known for its minimalist design and easy-to-use interface. Featuring a single side switch for activation and mode selection, the S15 includes high, medium, low, and moonlight outputs as well as a blinding strobe. Olight build the S15 from aviation grade aluminum and included an ingenious removable magnet inside the tail so you have the option of mounting the light to magnetic surfaces for hands-free area lighting in your workshop or under the hood.Best of all, the S15 can be fitted with 1 or 2 tube extenders (NOT Included), so you can double or even triple the run time with extra batteries. A super-strong pocket clip and IPX-8 waterproof rating means you can take the S15 anywhere. Features: Aviation grade aluminum body, with anti-scratch type III hard anodizing Stainless steel head ring can bear higher impact Side switch with blue button cap is soft and comfortable to press Special designed smooth reflector and anti-reflective lens Long-arm convertible pocket clip for easy access Flat bottom allows stable tail standing Reverse polarity protection Strong detachable magnet inside tail IPX-8 Water Resistance Optional tube extenders not included Includes: 1 x S15 Flahlight, 1 x Lanyard, 2 x Spare O-rings, Magnet replacer, User Manual Specifications: LED: CREE XM-L2 Runs on: 1 x AA battery (Alkaline or Ni-MH) OR 1 x 14500 Li-Ion Battery (NOT Included) Output/Runtime (With 14500 cell): High: 280 Lumens/45 Minutes Medium:70 Lumens/4 Hours Low:7 Lumens/32 Hours Moonlight: .5 Lumens/15 Days Peak Beam Intensity: 1750 cd Max Beam Distance: 91 yards (84 meters) Dimensions: Length: 3.4" (86mm) Diameter: .9" (23mm) Weight: 1.62oz (46g) [Исправлено: uV3, 27.06.2013 в 02:12] |
27.06.2013, 03:14 | 8 |
Регистрация: 09.01.2011 Последняя активность: 17.03.2022 15:19 Адрес: Киев
Сказал(а) спасибо: 274
Поблагодарили: 870 раз(а) в 271 сообщениях
Очень интересно то, что добавили возможность удлинять экстендерами.
ZL H600Fc Mk IV, H32w, H53fw, H53fc/ Nitecore D10 XM-L2 NW/ 47 Quark Mini AA High CRI, QP2A, QPA/ Olight S10L2 NW, S15 + extention tube/FENIX CL20O. 6 X 18650, 2 X AW R123A(750 mAH), 20 х AA ENELOOP, 31 X cr123a, 50 * AA LR6 DURACELL PROCELL, 68 * AA ENERGIZER L91 Ultimate Lithium. В планах: HDS Executive 2*AA, ZL SC5w MKII, H53w |
27.06.2013, 04:31 | 9 |
Регистрация: 04.02.2011 Последняя активность: 26.01.2022 12:36 Адрес: Украина. Днепропетровск.
Поблагодарили: 4533 раз(а) в 2375 сообщениях
Замахнулись стать идеальным на АА?!
27.06.2013, 04:32 | 10 |
Регистрация: 01.04.2013 Последняя активность: 03.04.2024 08:49 Адрес: В ссылке
Сказал(а) спасибо: 1768
Его бы сделали сразу на 4200К . А то потом опять выпустят ненужный титановый
27.06.2013, 05:38 | 11 |
Hoвичёк фонарёвки.
27.06.2013, 10:28 | 13 |
Регистрация: 08.03.2011 Последняя активность: Сегодня 16:04 Адрес: Питер
Записей в дневнике: 4 Сказал(а) спасибо: 15386
Поблагодарили: 33325 раз(а) в 12424 сообщениях
На 3АА забавно выглядит.
Аккумуляторы у них на картинках странные, брали бы уж популярные фонаревочные... А то что это за синий ноунейм на "1200mAh". И интересный "хвост" на разрядном графике 14500 - это у них аккум незащищенный? Или в фонаре есть встроенная защита лития? И что тогда на 2-3*АА происходит? [Исправлено: fnksb, 27.06.2013 в 10:32] |
27.06.2013, 12:00 | 14 |
Hoвичёк фонарёвки.
27.06.2013, 12:15 | 16 |
Hoвичёк фонарёвки.
Аа, я думал вы про тот слайд где разрядный график. )) |
27.06.2013, 13:32 | 17 |
читатель
27.06.2013, 13:40 | 19 |
читатель
fnksb,
27.06.2013, 17:41 | 20 |
вникающий
Регистрация: 23.12.2012 Последняя активность: 10.04.2024 21:05 Адрес: Владимир
Сказал(а) спасибо: 84
Поблагодарили: 27 раз(а) в 20 сообщениях
на данный момент каково имя популярного диода?
SIPIK SK(68,73) | Xeno E03(U2,T6-3C),F42(T6-3C) | Nitecore EC25W,HC50 | Convoy C8(T6) S6(T6-4C) | Olight S10,S15xm-l2,S10xm-l2 NW, S1 Baton,H1 Nova NW | EDIT P14 | HUGSBY P2 | SMALL SUN ZY-T13 | TANK007 TK-703 | SKILHUNT H02 NW |YLP G180 NW [/S]| |
