8450 11 2 0 |
19.03.2013, 19:48 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Review of charger Soshine SC-S1max V3
Soshine makes a couple of chargers and I have reviewed some before (S7,S2) they where acceptable but not perfect. This is revision 3 of a four channel charger, lets see if everything is perfect this time. The charger arrives in a cardboard box, that does also work as manual. Actual contents is the charger, a universal power supply (100-240 VAC 50/60Hz) and a car power adapter. Power input on the charger is a small DC connector, it need 12 volt 1.8A according to the label on the bottom of the charger. The bottom has the label and a lot of slots for air. The slots are not going to help much because the top of the charger does not have matching vents and when stuffed with batteries there is very little space around them (I did not notice any excess heating during tests). The charger has 4 leds one for each channel, that can be either red or green.
The connections are slightly raised, i.e. it can charge flat top batteries. The slider does slide smooth. Each slot is clearly marked with polarity and supported battery sizes. The charger is not rated for 26650 batteries, but it is possible to put one or two in the charger and charge them. The charger can handle over 70 mm long batteries, including flat top cells. Measurements
Charging a 3400mAh battery takes about 4½ hours. At 225 minutes (Where the green current line gets thick), the charger starts flashing green, i.e. signally that the charger is nearly finished. This feature is very useful when short on time, as can be seen on the blue mAh curve there is very little capacity gain during the next 30 to 60 minutes, before the battery is full. I.e. removing the battery when the green led flashes will give nearly full capacity, but save 30 to 60 minutes in charging time. The other 3 channels looks nearly equal to the first channel. Charging on all four channels at the same time, does not reduce the charge current, i.e. it will charge four batteries just as fast as one battery. There is more noise in the charge current, showing that the internal regulator is working much harder. A 3100mAh battery is slightly faster to charge. Going down to 2600mAh reduces the charge time to 3½ hour. The charger does also handle my old IMR cell, without any problem. This charger does not use softstart, but goes to full charge current shortly after power is connected. Testing the mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems. Conclusion This charger is not a charger with a lot of smart features, but for charging up to four 18650 batteries it does a very good job and the "nearly finished" indication on the leds is nice. For people that need to charge many 18650 it is a good solution. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Поблагодарили: 5 раз(а) |
Alex TG (19.03.2013), Leon (22.03.2013), MOHAPX (22.03.2013), NazarSunrise (22.03.2013), PinkFloyd (27.04.2013)
20.03.2013, 06:08 | 2 |
Регистрация: 26.12.2011 Последняя активность: 05.06.2015 03:09 Адрес: Северная Европа
Сказал(а) спасибо: 12
Re: Review of charger Soshine SC-S1max V3
Опа, внезапно. Зарядник на 4x 18650, который не сосёт (i4 под это определение не подходит). Придётся взять..
22.03.2013, 13:08 | 3 |
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 25.09.2023 22:54 Адрес: Львів
Сказал(а) спасибо: 1744
Как понять? Вы имели ввиду то, что при выключеном заряднике на нем минимальны токи утечки?
Продам фонари Convoy S3 с разной TIR оптикой |
22.03.2013, 19:10 | 4 |
22.03.2013, 19:24 | 5 |
Регистрация: 21.10.2011 Последняя активность: 17.11.2018 09:26 Адрес: V R N
Сказал(а) спасибо: 80
Поблагодарили: 1100 раз(а) в 429 сообщениях
чтоб обойтись без проставок берите версию микс
Sunwayman Thrunite Fenix и прочие по выгодной цене |
23.03.2013, 00:56 | 6 |
Turn Day into Night
23.03.2013, 01:01 | 7 |
Turn Day into Night
Спасибо, видел на DX, но для меня странное решение, почему не сделать 4-ре универсальных слота, с "полным ходом" минусовой клемы, к примеру как в тому же i4?, а вообще запутлся что брать, нет идеальной зарядки для лития, для АА проще, выбрал Маху или Лякрос и счастлив, а тут полно зарядок и нет даже намека на фаворита...
23.03.2013, 01:03 | 8 |
NazarSunrise (23.03.2013)
23.03.2013, 01:57 | 9 | |
Turn Day into Night
I am in search of the perfect charger for 18650, with 2-4 channels, 0.5-2A Now use the Nightcorei4, but I do not like it which is better (correct and accurate charging) : XTAR WP2, XTAR SP2, SC-S1, maybe some other chargers? |
23.03.2013, 02:10 | 10 | |
What you select, depends on your requirements: SP2: tow channels with up to 2A, SC-S1: four channels with fixed 1A. For my usage the VP1 is first and the SC-S1 is last, but I expect to use both chargers. |
23.03.2013, 06:00 | 11 |
Да, это делает эту зарядку очень удобной для тех, кто заинтересован в аккумах 26650.
Но обычным 18650 такой ток не очень реккомендуется, хотя с качественными аккумуляторами от известных брендов, а так же IMR аккумуляторами, его можно спокойно использовать. Но вот использовать 2A с разнофаерами я бы побоялся. |
23.03.2013, 14:16 | 12 |
Turn Day into Night
Думаю оптимальный ток - 1А, если надо срочно зарядить, тогда уже можно 2А. P.S. пользуюсь исключительно Panasonic NCR 18650B. |
