7280 11 9 1 |
08.02.2016, 19:56 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of LiitoKala Lii-100
LiitoKala Lii-100
LiitoKala has made a couple of analyzing charger, but this model cannot do any analyzing, it is a small universal charger that handles 3 types of LiIon and NiMH, it addition to this it can also work as a power bank. The packaing was very simple, being just a plastic bag. The pack contained the charger and a usb cable. The charger is powered from micro usb and has a full size usb connector for power bank output. The charger has two red leds to show selected current and four blue leds in a row to select voltage and show battery level. The button has multiple functions: When a battery is put into a powered charger, it can be used to select LiIon voltage (NiMH is selected automatic). When charger is powered a long press (2 seconds) will change between 0.5A and 1A charge current. A fast click when charging will show the selected battery type. When used as a power bank a press on the button will turn the usb power on. The charger uses the typical slider construction, it can handle batteries from 33mm to 70mm. The charger can handle 70mm long batteries, inclusive flat top cells, this means most protected cells. Measurements charger
Charging 4.20 volt LiIon The charger has a fine CC/CV voltage charge curve, it starts reducing current a bit early, due to voltage constrains, this will give slightly longer charge time. No surprise on these two cells. Reducing the charge current to 0.5A works fine, except the termination current is not reduced (Cells will miss the last few percent of the charge). With this older cell the current reduction starts very early as expected. Good charging on these smaller cell, again the higher termination current means a few percent loss in capacity. Adding a resistor in series with the usb power supply to simulate a long cable or weak supply did not prevent the charger from doing a good job, but it needed some more time. M1: 32,4°C, M2: 31,4°C, M3: 40,0°C, HS1: 48,8°C The charger needs some time to start up, this is because it is waiting for voltage selection. There is no problem with changing current while charging. Charging 4.35 volt LiIon The 4.35 volt charge works as expected. Charging 3.60 volt LiIon Both LiFePO4 cells is charged fine, but the voltage is a bit high (This is not a big problem with LiFePO4). Charging NiMH This is a fine NiMH charge with voltage termination and no trickle charge. When using voltage termination without a top-off charge the batteries will be slightly below full capacity. Using 0.5A charge current is also stopped on voltage termination. On this cell it looks like a voltage termination. Here it is -dv/dt termination. My new powerex cell is stopped on -dv/dt. The AAA cell is stopped on voltage. Fast detection of a full cell, this is voltage termination. M1: 35,4°C, M2: 34,2°C, M3: 41,9°C, HS1: 53,5°C The charger is also slow to start with NiMH, but it is not possible to select any other battery type. There is no problem with changing current while charging. The charger uses the typical pulsing, where it can measure voltage with current off. Power bank
USB output can deliver 1.3A before it starts dropping, the overload protection first kicks in at 2A. Running with 0.5A load looks very good. 1A output also looks very good. The noise is fairly good at 0.5A load with 20mV rms and 170mVpp At 1A the noise increases, but is still acceptable with: 38mV rms and 310mVpp Conclusion It looks like this model often is a bit high in charge voltage, but within allowable tolerances. I did not see any problems real with it. This makes it a good charger for all supported batteries and also a good power bank. Notes Here is an explanation on how I did the above charge curves: How do I test a charger Read more about how I test USB power supplies/charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Поблагодарили: 17 раз(а) |
Alex TG (10.02.2016), Angry Zeka (11.02.2016), Dima.shym (11.02.2016), drsleep (08.02.2016), LEV-UA (21.03.2016), m72 (09.02.2016), molvinec (14.02.2016), PopovSergej (11.02.2016), Qwertus (08.02.2016), rpdoctor (13.02.2016), Svetogor (12.02.2016), Tamagotchi (08.02.2016), vdavid (08.02.2016), Waryag (10.02.2016), witalen (11.02.2016), yurezz (11.02.2016), Андрей Светлов (08.02.2016)
11.02.2016, 20:35 | 2 |
Регистрация: 07.09.2015 Последняя активность: 21.11.2020 14:11 Адрес: Спб
Сказал(а) спасибо: 95
Поблагодарили: 121 раз(а) в 78 сообщениях
Re: Test/Review of LiitoKala Lii-100
Ну чего, Millerа в помойку?
11.02.2016, 21:21 | 3 |
Регистрация: 08.12.2013 Последняя активность: 16.04.2024 15:56 Адрес: Gomel
Записей в дневнике: 5 Сказал(а) спасибо: 2320
ну зачем сразу в помойку. 100 в режиме повербанка не удобная, 18650 выпадает из нее при малейшем чихе, да и в этом режиме греется. Носить мл 102 удобней будет.
Я себе МЛ 102 оставил в качестве ПБ и дополнительно ЗУ, а литокалу в качестве ЗУ и дополнительно ПБ.
11.02.2016, 22:33 | 5 |
Регистрация: 25.01.2015 Последняя активность: 05.05.2023 10:41
Сказал(а) спасибо: 268
Поблагодарили: 508 раз(а) в 322 сообщениях
12.02.2016, 13:31 | 6 |
Регистрация: 09.04.2011 Последняя активность: 23.10.2022 15:45 Адрес: Орел
Сказал(а) спасибо: 1044
Поблагодарили: 1032 раз(а) в 420 сообщениях
Зато габариты совсем другие ml102 по прежнему очень актуальна, была мысль отказаться от нее, но как портативный пауэр банк liitokala крайне неудобна.
ArmyTek Predator G109.1, Ferei 520(334 CREE XP-G2), Lux-RC FL33, Mag-Lite 3D Led, Mini Mag-Lite led pro+, Roche F12 Tir, XENO E03, Б44, Thrunite Ti. |
12.02.2016, 14:00 | 7 |
Регистрация: 04.11.2013 Последняя активность: 07.04.2021 14:31 Адрес: Курган, Курганская обл.
Сказал(а) спасибо: 118
Поблагодарили: 93 раз(а) в 78 сообщениях
Не забывайте, что литрокала еще и никельметалгидрид кушает, т.ч. эта поуниверсальнее будет нежели Miller. Миллер на подарок пошел.
Бери примeр с лучших, и ты увидишь, как берут примeр с тебя |
12.02.2016, 14:03 | 8 |
Регистрация: 10.04.2014 Последняя активность: 28.03.2024 14:08 Адрес: Нальчик, Искож
Сказал(а) спасибо: 864
Поблагодарили: 695 раз(а) в 446 сообщениях
да господи, хай кушает, только как часто внезапно нужно зарядить никель?) не все пожертвуют мобильностью в угоду универсальности
12.02.2016, 14:12 | 9 |
12.02.2016, 14:42 | 10 |
Регистрация: 21.01.2014 Последняя активность: 28.09.2020 11:00 Адрес: Москва и восток Замкадья
Сказал(а) спасибо: 66
миллер меньше раза в два, имеет бОльший ток заряда (1,33А в стоке) отдает не 1,3А а 1,7А. но достойный конкурент у миллера безусловно появился.
12.02.2016, 16:16 | 11 |
ML102_4.35V, Да у меня всё равно оба есть.
А вот китайский английский на заднике с ошибками |
16.02.2016, 21:00 | 12 |
Почти не ждун
Регистрация: 15.02.2012 Последняя активность: 06.11.2021 14:48 Адрес: СПб
Сказал(а) спасибо: 217
Поблагодарили: 274 раз(а) в 136 сообщениях
Приехала зарядка, пока изучаю. С защищенными 18650 от AW (на 2600, скольки-то летней давности) не дружит, нужен магнитик на плюсовой контакт. LG HG2 и Sanyo GA (плюс выдается чуть больше, чем у LG) - без проблем.
