Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров SKILHUNT
Просмотров в теме 11471   Ответов в теме 14   Подписчиков на тему 6   Добавили в закладки 1
Старый 09.12.2014, 12:03 Автор темы   1
Аватар для skilhunt
Последняя активность: 19.04.2024 11:51
Поблагодарили: 133 раз(а) в 44 сообщениях
:sun_smile: NEW release! SKILHUNT H02C RGBW Colorful headlamp
Hello everyone,
Good news!
NEW release! SKILHUNT H02C RGBW Powerful headlamp.
Specification:
LED: CREE XML-Color LED
Weight:56g(excluded battery)
Power:1*18650 battery
Rated range:3V ~ 4.2V
Dimension: Length:110mm/4.33 inch
Head diameter:25mm /0.98 inch
Body diameter:22.8mm
Lens:P.T.I.R Lens
Color:Black
Waterproof to IPX-8
Impact Resistant:1.5 Meters
Accessories:Opetator´s manual, Warranty card, Spare O-rings, Magnet replace O-ring, Lanyard, Clip, Headband
Optional accessories: Battery, Charger
Wight light modes: / Runtime:
Turbo 260 LED Lumens / 2 Hours and 30 Mins
High 140 LED Lumens / 5 Hours
Med 50 LED Lumens / 12 Hours
Low 2 LED Lumens / 480 Hours
SOS 260 LED Lumens / 5 Hours
Beacon 260 LED Lumens / 5 Hours
Color light Red Green Blue
DWL 620-630 nm 520-535 nm 450-465 nm
OUTPUT Hi 100/ Lo25 LED lumens Hi 150/ Lo 30 LED lumens Hi 30/ Lo 5 LED lumens
Runtime Hi 3.0/ Lo 18 Hours Hi 2.5/ Lo 18 Hours Hi 2.5/ Lo 18 Hours
Easy and Trusty user interface operation:
1. When the flashlight was OFF status:
- Click the side switch to White Mode brightness level, cycle as Lo - Mid- Hi - Turbo. Quickly double press side switch to Color High Mode.(Double press back to White light mode.)
- Hold press the side switch 0.5 second to Color High Mode, cycle as Red - Green - Blue. Quickly double press side switch to White Mode.(Double press back to Color High mode.)
- Quickly double press side switch to Color Low Mode. Double press to specical mode, cycle as SOS - Beacon. (Double press back to Color Low mode.)
When the flashlight was ON (any mode) status:
- Hold press the side switch 0.5 second, turn off the flashlight.
Low voltage indication:
When the battery voltage drop down, the light will blink three times every 2 minutes.
Features:
1. Super bright & lastest CREE XML-Color LED, High-Performance, High-Efficiency and energy conservation.
2. P.T.I.R Lens, Efficiency reflection, perfect beamshot.
3. Four output levels and Strobe, suitable for different environment.
4. Flat tail with strong magnet to secure to ferrous surfaces.
5. Rugged indestructible aluminum body with anti-scratching type III hard anodization.
6. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
7. Side mode switch button to transferring mode, user friendly inerface to adjust output.
8. High efficiency driver circuit.
9. Reverse polarity protection, to protect from improper battery installation.
10. Low-voltage indication, the light will flash when the battery is low, remind user replace the battery on time.
11. Engineered anti-slip knurling for a tightly firm grip.
12. Dual recoil absoring springs, bettery impact resistance.
13. Tail stand as a candle-light.
14. Tail hang hole design for lanyard use, to prevent accidental dropping.
Details
[Исправлено: skilhunt, 11.12.2014 в 05:06]
skilhunt вне форума   Ответить с цитированием Вверх
Lumenbox.ru (23.01.2015), m72 (27.11.2016), Svetogor (23.12.2014)
Старый 09.12.2014, 12:09   2
Burlaew
Последняя активность: 02.12.2020 22:19
Сказал(а) спасибо: 519
Поблагодарили: 142 раз(а) в 91 сообщениях
По умолчанию Re: NEW release! SKILHUNT H02C RGBW Powerful headlamp
Интересно! А не будет ли хот спот не правильной формы из-за того, что кристаллы смещены относительно оси?
Burlaew вне форума   Ответить с цитированием Вверх
Старый 09.12.2014, 12:17   3
asket32420
Шурик с шуриком
Аватар для asket32420
Последняя активность: 27.01.2024 21:46
Сказал(а) спасибо: 2009
Поблагодарили: 2601 раз(а) в 1436 сообщениях
На иглтаке таком так и есть, кривые споты
Burlaew (09.12.2014)
Старый 22.12.2014, 04:38   4
Valerianis
Аватар для Valerianis
Последняя активность: 25.03.2020 05:51
Сказал(а) спасибо: 359
Поблагодарили: 181 раз(а) в 114 сообщениях
Уже в продаже, 54-57 долларов:
http://www.gearbest.com/led...
http://www.banggood.com/SKI...
[Исправлено: Valerianis, 22.12.2014 в 04:40]
Valerianis вне форума   Ответить с цитированием Вверх
Старый 23.12.2014, 14:33   5
ip_86
Последняя активность: 13.03.2016 07:28
Сказал(а) спасибо: 764
Поблагодарили: 557 раз(а) в 210 сообщениях
Очень интересная новинка, только непонятно, диод какой группы С2 или С3.
Ко мне уже едет сабж, так что обязательно сделаю обзор.
ip_86 вне форума   Ответить с цитированием Вверх
Старый 23.01.2015, 11:48   6
Rocklight
Аватар для Rocklight
Сказал(а) спасибо: 1116
Поблагодарили: 1650 раз(а) в 958 сообщениях
Забавный конечно фонарь. Особенно система управления веселит. Не так логична как на зебре но запоминается быстро.
Хот спот кривой во всех цветах, что ожидаемо. Но не так страшно в практике ИМХО.
Пищит на малых режимах сильно. Цвета сочные и ядреные. Лезут все акки даже кипповеры с сейко защитой.
Мне кажется, есле бы был режим со стробом перебирающим цвета, был бы мега праздничный фонарь! Жаль что нет такого, строб и сос белый. Хотя строб более похож на маяк, не агрессивный и спокойный.
Ждем зебру с таким диодом...
Избаловала конечно меня зебра своим выбором режимов. Точнее количеством, а тут их прямо в 4 раза больше нужно.
Нужно отметить что такого ядреного синего я в фонарях еще не видал. Ни с фильтром не на индикаторных пендотактиках. Тут он прям вах вах. Жаль что сейчас зима. Хотя и так в лесу с этим цветом прям кусок пандоры и наави вокруг шныряют, не важно что в сугробах. Так и ждешь шестиногого чудовища из за дерева...
В общем с эмоциональной точки зренияможно прировнять этот фонарь к походу в кино.
[Исправлено: Rocklight, 23.01.2015 в 11:59]
Старый 23.01.2015, 12:03   7
Valerianis
Было бы хорошо иметь перебор яркости по каждому цвету, имхо.
А к чему он вообще, этот синий там? Это же не рыбацкий УФ: рыбы, наверное, его будут пугаться?
Пока вижу применение только как тактик со своим ярким красным цветом, ну и в основном как сигнальный фонарь.
Tarans (22.03.2017)
Старый 23.01.2015, 12:22   8
Rocklight
Да, два режима на цветных маловато.
Синий таки интересен в плане позабавить детей. Многие белые вещи начинают подсвечиваться. Может быть таки карты при нем читать будет легче, это буду проверять позже.
Свет красный у него не сказать чтоб прям сильно яркий. Моя полосатая н32r его пересвечивает. Хотя понятно что рефлектор дальше бъет. Но сумммрно по ощущениям в зебре 100 люмен весят больше чем в скиле.
[Исправлено: Rocklight, 23.01.2015 в 12:25]
Старый 23.01.2015, 13:23   9
Valerianis
Там разве два режима интенсивности на цветных, а не по одному на каждом цвете?
Старый 23.01.2015, 13:57   10
Lumenbox.ru
Аватар для Lumenbox.ru
Последняя активность: 21.09.2015 16:05
Сказал(а) спасибо: 32
Поблагодарили: 65 раз(а) в 21 сообщениях
Посмотреть сообщение Сообщение от Valerianis :
Да вот собственно и в шапке висит инфа
OUTPUT Hi 100/ Lo 25 LED lumens - красный
Hi 150/ Lo 30 LED lumens - зеленый
Hi 30/ Lo 5 LED lumens - синий
Магазин хороших фонариков www.lumenbox.ru
Lumenbox.ru вне форума   Ответить с цитированием Вверх
Старый 23.01.2015, 14:00   11
Rocklight
[nick="Lumenbox.ru"] да именно так. В реальном экземпляре тоже.
Только управление замудренное. Выход в минимальные цветные с выключенного фонаря двойным кликом.
Valerianis (23.01.2015)
Старый 13.11.2016, 22:21   12
GAME OVER
don't fuck my brains
Аватар для GAME OVER
Последняя активность: 26.01.2024 14:02
Сказал(а) спасибо: 634
А случаем внутрь не заглядывали, расчленёнку не производили? Драйверок там такое же недоразумение как в обычных H02, Т образный - из двух плат составлен?
Или другой конфигурации, просто круглый как в H03?
[Исправлено: GAME OVER, 13.11.2016 в 22:24] Причина: Потому что "профессор".
GAME OVER вне форума   Ответить с цитированием Вверх
Старый 14.11.2016, 11:10   13
Rocklight
Расчлененки не делал, но почему то мне думается что как в 02, так как эта модель почти ровесница 02. Уверен на 90% что драйвер сильно менять не стали бы под фонарь с непонятными перспективами.
Хотя фонарь уникальный и единственный в своем роде!
Фонарей много не бывает!
GAME OVER (14.11.2016)
Старый 14.11.2016, 20:27   14
GAME OVER
Rocklight, Тоже заказал, себе в подарок к НГ.
Разберу гляну, выложу фото, по всему тырнету нету фотки расчленёнки этого фонаря, действитно уникальный..
Подозреваю что может быть другой, по разводке должен сильно отличатся, может и конфигурация платы другая, драйвер может быть даже двух этажный.
Таки 8 точек подключения вместо двух.
PS и таки он другой, вот что нашёл, правда только одна сторона, но понять можно что разводка сильно другая.
Взял здесь http://www.forolinternas.co...
Вот фотка обычного H02
[Исправлено: GAME OVER, 14.11.2016 в 22:03] Причина: Потому что "профессор".
Старый 26.11.2016, 23:37   15
GAME OVER
Выкладываю обещанные фото, таки я оказался прав, угадал.
rino08 (27.11.2016)
Время генерации страницы 0.11955 секунды с 16 запросами
