3451 11 7 0 |
11.08.2018, 07:27 | 1 |
What is your poll and best idea on ACEBEAM headlamp H30?
Typical features: * 21700 5100mAh rechargeable battery assures the much longer run time for the outdoor activities * The brightest 4000 lumens output for the emergency * Lowest temperature resistance to -20℃ * USB-C 3 times faster charging speed * Color temperature: 5000K & 6500K for option * Waterproof IPX8 * Special mode only SOS without Strobe POLL 1: Solution 1 or 2? Red SOS: the 21700 5100mAh battery ensures the run time up to a few days or even more with SOS modes, and the SOS continuously keeps flickering until the battery is run out without turning off the light.There are two solutions: Solution 1) Keeping SOS continuously flickering until the battery is run out, which will lead to battery damage. Solution 2) Setting the light turn off when the voltage is at 2.7V. We prefer the solution one that keep the SOS flickering until the battery is used up, as we think human life is much more precious than battery when waiting for the rescue outside even though the run-out battery will lead to battery damage. How do you think? POLL 2: Red + IR, Red + UV, Red + CRI90, which version you prefer? ACEBEAM H30 is specially designed with Red and Green Light for outdoor hunting, and also it might be made with optional versions: Red + IR Red + UV Red + CRI90 We highly appreciate your poll and best idea. sales@acebeam.com
www.acebeam.com [Исправлено: Acebeam Light, 11.08.2018 в 08:19] |
11.08.2018, 08:15 | 2 |
Регистрация: 15.03.2017 Последняя активность: Сегодня 22:23 Адрес: Север
Сказал(а) спасибо: 7677
Поблагодарили: 3516 раз(а) в 2071 сообщениях
Re: What is your poll and best idea on ACEBEAM headlamp H30?
Acebeam Light (17.08.2018)
11.08.2018, 09:15 | 3 | |
Убивать батарейки сосом и светить инфракрасно в темноте. Раз не из чего выбирать...
Почему CRI90 предлагается опционально, если основной xhp70.2 заявлен better color rendering? Где обман? Цитата:
трол. |
11.08.2018, 09:46 | 4 |
Регистрация: 14.08.2011 Последняя активность: Сегодня 21:38 Адрес: до Урала
Записей в дневнике: 10 Сказал(а) спасибо: 6841
Поблагодарили: 6965 раз(а) в 3311 сообщениях
1. Solution 1) Keeping SOS continuously flickering until the battery is run out, which will lead to battery damage.
2. "...and there are 1*Red LED and 1*Green LED to alert others..." Originally you had red and blue light. Red + Dark Blue (It is the "police color light for police usage")
Do not buy if you do not know what you are doing! Убил - отпусти! [Исправлено: Медветь, 11.08.2018 в 10:01] |
13.08.2018, 00:28 | 6 | |
Регистрация: 11.09.2015 Последняя активность: 05.02.2023 09:48 Адрес: Сумы
Поблагодарили: 2775 раз(а) в 1772 сообщениях
Up to 30W? [Исправлено: Waryag, 13.08.2018 в 00:31] |
13.08.2018, 01:20 | 7 |
HID маньяк
Регистрация: 04.09.2010 Последняя активность: Сегодня 12:45 Адрес: Это Питер, детка (с)
Сказал(а) спасибо: 778
Поблагодарили: 2571 раз(а) в 880 сообщениях
14.08.2018, 13:42 | 8 | |
Yes, all right. The 4000lumens is white light 1*XHP70.2 LED. |
16.08.2018, 20:08 | 9 |
Регистрация: 12.04.2015 Последняя активность: 23.04.2024 15:06 Адрес: Москва, беляево
Сказал(а) спасибо: 713
Поблагодарили: 637 раз(а) в 410 сообщениях
"Setting the light turn off when the voltage is at 2.7V." And "Keeping SOS continuously flickering until the battery is run out" after removing and replacing a tailcap
Red + UV + 90 CRI Xhp70. 2 |
blindnick (16.08.2018)
17.08.2018, 09:31 | 10 |
29.10.2018, 16:19 | 11 |
Регистрация: 17.07.2014 Последняя активность: Сегодня 19:49 Адрес: Иваново
Сказал(а) спасибо: 1412
Поблагодарили: 888 раз(а) в 201 сообщениях
31.10.2018, 10:24 | 12 | |
Acebeam H30 Review https://forum.guns.ru/forum... https://forum.fonarevka.ru/... https://www.taker.im/review... https://shopper.life/obzor-... |
