5728 13 4 1 |
04.05.2015, 05:08 | 1 |
Acebeam new products ! K60 ultra-long throw XHP70 LED Flashlight published
Acebeam new products K60 announced. Ultra-long throw ! Super bright 5000lumens !
Features: LED: Cree XHP70 LED with a lifespan of 10+years of run time Max 5000lumens output using (4x 18650 power cell) Output (select by magnetic ring): Level 1 : 1lm 1300hours; Level 2 : 50lm 140 hours; Level 3 : 700lm 20 hours; Level 4 : 1700lm 5.5 hours; Level 5 : 4000lm 1.6 hours; Level 6 : 5000lm 1.5 hours; Standby : 65uA Strobe : 5000lm 3 hours; Working voltage: 4V - 17V; Max Runtime: 1300 hours; Max beam distance: 704meters; Peak beam intensity: 124100cd; Impact resistant: 1.2 meters; Waterproof : IPX-8 Standard (2meters); Size: 206mm(length) x 88mm(head diameter)*50mm(tube diameter); Weight: 570g(without batteries); Aircraft grade aluminum body structure; Premium type III hard anodized anti-abrasive finish. ultra-clear tempered glass lens with anti-reflective coating. Strobe mode for tactical and emergency use Smooth reflector for maximum distance. tactical knurling for firm grip streamlined body design Mechanical reversed polarity protection design for battery carrier Intelligent highly effcient circuit board design for max performance and long run time; Specially designed for military,Law Enforcement, Self-defense, Hunting,Search&Rescue and outdoor activities. Intelligent temperature controlled light output for user safety Accessories include: 1x user manual 1x warranty card 1x lanyard 1x holster 2x Replacement O-rings 1x Replacement Tail cap Caution: Highly recommend using unprotected high drain battery (ARC18650H-250A) which at least 20A 2500mAh, the circuit might be tripping if use protected one. Acebeam Team
www.acebeam.com |
04.05.2015, 21:02 | 2 |
Регистрация: 07.10.2011 Последняя активность: 23.02.2024 17:30
Сказал(а) спасибо: 52
Поблагодарили: 50 раз(а) в 43 сообщениях
Re: Acebeam new products ! K60 ultra-long throw XHP70 LED Flashlight published
Как купить и сколько стоит?
17.05.2015, 08:55 | 3 |
Регистрация: 19.09.2011 Последняя активность: 23.11.2023 13:13 Адрес: NN
Дайте на него купончик, очень хочется приобрести
18.05.2015, 06:58 | 4 |
Неехидный Котэ
Регистрация: 12.12.2014 Последняя активность: 19.05.2019 06:53
Сказал(а) спасибо: 10
Acebeam Light, Фото как светит есть?
24.05.2015, 00:29 | 5 |
Регистрация: 22.05.2015 Последняя активность: 16.02.2019 22:52 Адрес: Москва
Сказал(а) спасибо: 44
Поблагодарили: 31 раз(а) в 28 сообщениях
на ебее по 200 долларов
http://www.ebay.com/itm/Ace... |
26.05.2015, 16:41 | 6 |
Регистрация: 24.02.2013 Последняя активность: 04.07.2017 11:53
27.05.2015, 05:02 | 7 |
Ultrafire, ток через акумы не мерили? Ко мне тоже выехал данный девайс
27.05.2015, 05:23 | 8 |
Кстати он в какой упаковке должен быть? Коробка или алюминиевый кейс?
27.05.2015, 06:49 | 9 |
Картонная упаковка, такая как в самом начале темы на картинке.
27.05.2015, 13:19 | 10 |
02.06.2015, 15:05 | 11 |
Регистрация: 17.10.2013 Последняя активность: 25.11.2023 17:27
Сказал(а) спасибо: 6
Поблагодарили: 154 раз(а) в 69 сообщениях
Вопрос обладателям - как считаете, если есть Imalent DDT40, есть смысл этот приобретать?
03.06.2015, 06:33 | 12 |
Ну тут на вкус и цвет конечно...
Вот вы например зимой (когда чаще всего темно вечером) на Ималенте как будете в перчатках переключать режимы? Перчатки снимать? Ну ималент конечно будет поменьше по размерам, но всеравно, ИМХО не карманный фонарь. |
03.06.2015, 06:34 | 13 |
03.06.2015, 06:45 | 14 |
τετραγράμματον
Регистрация: 27.04.2013 Последняя активность: 21.04.2024 09:37 Адрес: В евонном поиске!
Сказал(а) спасибо: 179
