7282 11 5 1 |
04.02.2017, 19:27 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/review of Charger Olight UC
Charger Olight UC
Olight has made a very simple charger with no slots, but only magnets for battery connections. This is nothing new, except Olight has improved it significantly: Both LiIon and NiMH and no polarity. The pack is very simple and contains only the charger. The clear plastic around the wire has a red and green led behind it. This means it will be read while charging and green when done. The led will flash slowly red when not connection to any battery (Both with open and shorted connections). The leds are fairly weak. In this block the wire split into two, one for each end of the battery. The two magnets. Here the magnets are connected to a battery. Only limit on battery size is charge current. The current is a bit high for small cells, but some 14500 and 16340 will be acceptable because the current drops when voltage increase. Measurements
The charger uses CC/CV charging, but cannot deliver full current when the battery voltage is above 3.9V, termination is at 100mA. This is a good charge curve. This cell has higher charge voltage and the current will be a bit below maximum current. Works fine. This cell is old, again the charge voltage is high and the current drops a bit. On paper the charger current is too high for these cells, but in praxis it is not that bad. A new cell would be charged with too high current at the start of charge and this is the time where the battery can best tolerate it. Here I have added a 0.5ohm resistor in series with the usb power to simulate a long cable or weak usb charger. The charger do not handle that well, it terminates at 4.1V and 400mA. M1: 33,2°C, M2: 25,7°C, HS1: 43,0°C The charger get a bit warm and the battery stays cool. It takes a few second for the charger to initialize a LiIon charge. NiMH batteries The charger uses voltage detection for NiMH batteries and not any significant top-off or trickle charge. This means the batteries will be slightly below a full charge. The charge current for NiMH is 500mA The eneloopPro and powerex are handled fine. The charger cannot handle my old worn out eneloopXX (This battery is not really useable anymore). The AAA cell is handled fine. With voltage termination the charger is fairly fast at detecting a full cell M1: 35,7°C, M2: 26,0°C, HS1: 47,5°C The charger get a bit warm, but the battery stays cool. The power on sequence is a bit long when charging NiMH. The charger is fairly fast to get into the precharge phase, but there are some strange pulses. I do not know the reason for these pulses, they do both look the same. They do not prevent the charger from trying to charge alkaline cells. As usual for a NiMH the current will be turned off when checking voltage. Conclusion This is a very compact usb charger and it is fairly useful for many cells, it works best with a good stable usb power. Because the charger is isolated from the cells it will never heat them. I like the automatic polarity, but I would have like the charge indication leds to be a lot brighter. I will call it a good charger and the best I have seen of this type (usb with magnetic clamps). Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Поблагодарили: 12 раз(а) |
DoubleDragon (04.02.2017), PinkFloyd (19.05.2021), PopovSergej (06.02.2017), rpdoctor (04.02.2017), SML (04.02.2017), Storm (05.02.2017), vorsmann (05.02.2017), VovanV (04.02.2017), Алексей Михайлович (06.02.2017), Андрей Светлов (04.02.2017), Бармалей (05.02.2017), ФанКол (13.01.2024)
04.02.2017, 21:07 | 3 |
Регистрация: 12.05.2014 Последняя активность: 16.04.2024 22:01 Адрес: Долгопрудный-Лобня-Москва
Записей в дневнике: 1 Сказал(а) спасибо: 790
Поблагодарили: 752 раз(а) в 539 сообщениях
Re: Test/review of Charger Olight UC
И брать несколько, включая многослотовую USB ЗУ.
И не нужны никакие 4-слотовые ЗУ.
фонари Zebralight |
04.02.2017, 22:38 | 5 |
Регистрация: 21.06.2010 Последняя активность: 17.03.2024 18:09 Адрес: Ялта
Сказал(а) спасибо: 21
Мне нравиться
04.02.2017, 23:08 | 6 |
HID маньяк
Регистрация: 04.09.2010 Последняя активность: Вчера 19:11 Адрес: Это Питер, детка (с)
Сказал(а) спасибо: 778
Поблагодарили: 2569 раз(а) в 880 сообщениях
05.02.2017, 01:33 | 7 | |
33°N 118°W
Регистрация: 21.12.2015 Последняя активность: 21.01.2024 21:47
Сказал(а) спасибо: 841
Поблагодарили: 740 раз(а) в 283 сообщениях
Как оказалось, зарядка приемлема для некрупного лития. Вначале заряда ток выше рекомендованного, но он снижается по мере роста напряжения.
05.02.2017, 03:52 | 8 |
Регистрация: 18.06.2015 Последняя активность: 20.02.2024 00:04 Адрес: Татарстан
Сказал(а) спасибо: 185
Поблагодарили: 77 раз(а) в 49 сообщениях
Dmitriyrus,
А какое напряжение на литии сразу после окончания зарядки? Судя по графику, она малеха на 0,01-0,02 перезаряжает? |
05.02.2017, 14:30 | 9 |
Ветеринар Фонаревки
Регистрация: 19.03.2013 Последняя активность: 18.04.2024 15:13
Сказал(а) спасибо: 9616
Поблагодарили: 2227 раз(а) в 1446 сообщениях
Очень ждал этого обзора. Но не утерпел и заказал с офф сайта уже получил работает адекватно. Главное не греет аккумуляторы.
In Fino verytas |
06.02.2017, 07:57 | 10 |
33°N 118°W
Nab, после заряда на моей 4.18 В. Новый UR14500P.
Пропустил момент померить в финальной стадии самого процесса зарядки. Сделаю в другой раз. |
nab (06.02.2017)
31.01.2018, 14:26 | 11 |
Регистрация: 09.06.2013 Последняя активность: 13.08.2023 20:22 Адрес: Днепр
Поблагодарили: 11 раз(а) в 9 сообщениях
А каким током она заряжает аккумы?
31.01.2018, 14:36 | 12 |
AlexeyDnepr,
750-850 mA |
AlexeyDnepr (31.01.2018)
