5677 15 4 0 |
29.04.2014, 13:14 | 1 |
Регистрация: 08.08.2011 Последняя активность: 19.04.2024 11:51
Поблагодарили: 133 раз(а) в 44 сообщениях
New release, SKILHUNT DS20 EDC 480lumens flashlight
Hello Everyone,
New release, SKILHUNT DS20 EDC 480lumens flashlight More details LED: CREE XM-L2 Max output: 480 Lumens Max runtime: 240 h Max beam distance: 123 m Max peak beam intensity: 3800 cd Waterproof: IPX-8 Impact resistant: 1.5 Meter Battery: 1x18650 , 2x CR123A or 2x 16340 Rated Range: 3V ~ 9V Dimension: Length 110 mm/4.33 inch Head diameter 24 mm/0.94 inch Body diameter 22 mm/0.86 inch Weight: 55 g / 1.9 oz (without battery) Accessories: Clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring Optional Accessories: Headband, Battery,Charger Features 1. Super bright & lastest CREE XM-L2 LED, High-performance, High-efficiency and energy conservation. 2. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure and temperature resistance. 3. Toughened ultra-clear glass lens with 99% luminousness anti-reflective coating. 4. Rugged indestructible aluminum body with anti-scratching type III hard anodization. 5. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity. 6. Side switch button to transferring mode user-friendly interface to adjust output. 7. Four output levels and strobe, suitable for different environment. 8. Wide input range provides more choices of batteries. 9. Automatic memory function, remember bast used setting and can be preset to specific output mode for instant access. 10. Reverse polarity protection, to protect from improper battery installation. 11. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery on time. 12. Engineered anti-slip knurling for a tightly firm grip. 13. Dual recoil absorbing springs, battery impact resistance. 14. Tail stand as a candle-light. 15. Tail hand hole design for lanyard use, to prevent accidental dropping. |
29.04.2014, 13:38 | 2 |
старожил
Регистрация: 25.05.2012 Последняя активность: 11.11.2021 19:36 Адрес: Санкт-Петербург
Сказал(а) спасибо: 661
Re: New release, SKILHUNT DS20 EDC 480lumens flashlight
I want it! I need it!
Where to buy?
Klarus XT11, Thrunite Neutron 1A, Solarforce Z2/X3, Convoy S2, EagleEye X6 XPL HI, Xeno S3a v2, Skilhunt H02W Околофонарные мелочи |
29.04.2014, 14:25 | 5 |
Olight fan
Регистрация: 12.03.2011 Последняя активность: 04.07.2022 22:01 Адрес: Киев, Украина
Сказал(а) спасибо: 5056
Скоро модели DS10, DS15 и DS20 появятся в Skilhunt Украина в г.Киеве.
Постараюсь сразу набросать обзорчик.
Лучший фонарь - это фонарь, который оказался у тебя в руке, когда наступила темнота. |
29.04.2014, 15:11 | 6 |
Регистрация: 22.01.2012 Последняя активность: 29.01.2021 06:54 Адрес: Екатеринбург
Сказал(а) спасибо: 948
Поблагодарили: 355 раз(а) в 232 сообщениях
Налобник с ТИР. В соседнем обзоре про S15 я попросил про него инфу. Даешь больше вкусных налобников, товарищи)))
SC51, Н600F, H602w, H600w mkII, Niteye JA10, ThruNite TN10 (NW), Jetbeam BC40, Bronte X03 (NW), Bronte RA04 (NW XM-L), Tank007 e09, Xeno E03, Olight S20 |
29.04.2014, 16:01 | 7 | |
Регистрация: 08.03.2011 Последняя активность: Сегодня 04:31 Адрес: Питер
Записей в дневнике: 4 Сказал(а) спасибо: 15411
Поблагодарили: 33363 раз(а) в 12438 сообщениях
И правда интересно, хотя и слишком похоже на армитек. PS. А кто знает, где хорошо покупать Skilhunt? Кроме DX и пары случайных на HKE их особо не встречал, адекватных дилеров в России вроде тоже нет. [Исправлено: fnksb, 29.04.2014 в 16:05] |
29.04.2014, 16:09 | 8 |
Регистрация: 06.09.2013 Последняя активность: 29.09.2020 12:03 Адрес: Ukraine
Сказал(а) спасибо: 465
Поблагодарили: 226 раз(а) в 170 сообщениях
29.04.2014, 16:11 | 9 |
Фонарик - смесь Санвея С20С, Роше Ф6 и Олайт Эс20 Батона... Интересно, какие будут цены. ДС20 больше 50уе потянет?...
29.04.2014, 16:26 | 10 |
Olight fan
Цен пока нет, но 20ый скорее всего более 50$.
Я сразу отпишусь, как будет информация |
_rider (29.04.2014)
29.04.2014, 16:32 | 11 |
29.04.2014, 16:51 | 12 |
Olight fan
Сейчас скидки уже есть на продукцию SKILHUNT, думаю, она будет распространяться и на новые модели.
26.05.2014, 01:40 | 13 |
havoc (26.05.2014)
10.06.2014, 11:24 | 14 |
Получил DS20.
Неплохо, но первые впечатления менее позитивны, чем в blf-ном обзоре DS10. Фонарь интересный, но выкидывать олайты и санвеи еще рано. Вечером постараюсь заобзорить. |
10.06.2014, 11:29 | 15 |
10.06.2014, 21:13 | 16 |
Ловите: https://forum.fonarevka.ru/...
Я очень надеюсь, что Skilhunt прислушается к отзывам. А в будущем будет отправлять фонари на независимые тесты, прежде чем выпускать в продажу... to skilhunt: if necessary, I can make a short list of the main drawbacks. [Исправлено: fnksb, 10.06.2014 в 21:38] |
