5434 14 6 0 |
25.04.2014, 06:57 | 1 |
Регистрация: 08.08.2011 Последняя активность: 19.04.2024 11:51
Поблагодарили: 133 раз(а) в 44 сообщениях
New release, SKILHUNT DS10 EDC 300lumens flashlight
Hello everyone,
New release, SKILHUNT DS10 EDC 300lumens flashlight More details DS10 LED: CREE XM-L2 Max output: 300Lumens Max runtime:140hours Max beam distance:98m Max peak beam intensity:2400cd Waterproof: IPX-8 Impact resistant: 1.5 Meter Battery: 1x16340 or 1x CR123A Rated Range: 2V ~ 4.2V Dimension: Length 75mm/2.95inch Head diameter 24mm/0.94inch Body diameter 22mm/0.86inch Weight: 47g / 1.65oz (without battery) Accessories: Clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring Optional Accessories: Headband Features 1. Super bright & lastest CREE XM-L2 LED, High-performance, High-efficiency and energy conservation. 2. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure and temperature resistance. 3. Toughened ultra-clear glass lens with 99% luminousness anti-reflective coating. 4. Rugged indestructible aluminum body with anti-scratching type III hard anodization. 5. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity. 6. Side switch button to transferring mode user-friendly interface to adjust output. 7. Four output levels and strobe, suitable for different environment. 8. Wide input range provides more choices of batteries. 9. Automatic memory function, remember bast used setting and can be preset to specific output mode for instant access. 10. Reverse polarity protection, to protect from improper battery installation. 11. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery on time. 12. Engineered anti-slip knurling for a tightly firm grip. 13. Dual recoil absorbing springs, battery impact resistance. 14. Tail stand as a candle-light. 15. Tail hand hole design for lanyard use, to prevent accidental dropping. [Исправлено: skilhunt, 25.04.2014 в 08:15] |
25.04.2014, 09:07 | 2 |
Регистрация: 07.04.2011 Последняя активность: 05.07.2019 16:52
Сказал(а) спасибо: 25
Re: New release, SKILHUNT DS10 EDC 300lumens flashlight
How about a free sample for review?
25.04.2014, 11:44 | 3 |
Регистрация: 25.03.2014 Последняя активность: 26.02.2015 19:55
Сказал(а) спасибо: 320
Поблагодарили: 260 раз(а) в 143 сообщениях
And when Skilhunt H02 will be released?
29.04.2014, 07:42 | 5 |
Please send email to us service@skilhunt.com
Thanks. |
29.04.2014, 07:44 | 6 |
The H02 is ready, we will release it these two days.
29.04.2014, 07:44 | 7 |
DS20 will release these two days.
29.04.2014, 07:48 | 8 |
старожил
Регистрация: 25.05.2012 Последняя активность: 11.11.2021 19:36 Адрес: Санкт-Петербург
Сказал(а) спасибо: 661
When and where DS10/20 purchase will be available?
Klarus XT11, Thrunite Neutron 1A, Solarforce Z2/X3, Convoy S2, EagleEye X6 XPL HI, Xeno S3a v2, Skilhunt H02W Околофонарные мелочи |
29.04.2014, 10:06 | 9 | |
29.04.2014, 10:10 | 10 |
Регистрация: 06.09.2013 Последняя активность: 29.09.2020 12:03 Адрес: Ukraine
Сказал(а) спасибо: 465
Поблагодарили: 226 раз(а) в 170 сообщениях
29.04.2014, 15:22 | 11 |
I want buy H02 to review, if price will be acceptable . Will be pleased for the link to shop, where i can preorder this flashlight.
29.04.2014, 15:27 | 12 |
Olight fan
Регистрация: 12.03.2011 Последняя активность: 04.07.2022 22:01 Адрес: Киев, Украина
Сказал(а) спасибо: 5056
Он еще не выпущен, только что узнавал, пока только DS10-15-20. Тот будет не раньше чем через месяц.
Лучший фонарь - это фонарь, который оказался у тебя в руке, когда наступила темнота. |
29.04.2014, 15:34 | 13 |
Ну да, обещали анонс в ближайшие два дня. Но это же не преграда желанию. Как по мне, интересный налобник.
29.04.2014, 15:41 | 14 |
Olight fan
именно так, но до серии еще далеко.
А Н02 действительно интересный экземпляр! |
02.09.2015, 14:20 | 15 |
Регистрация: 02.08.2015 Последняя активность: 17.09.2017 12:03 Адрес: республика Хакасия, город Саяногорск
Сказал(а) спасибо: 9
Кто нибудь уже пользовался?
Резьба очень мелкая? |
