6607 12 3 0 |
11.10.2015, 18:24 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Charger Keeppower L1
Keeppower is known for its LiIon batteries, but now they have also made a charger. It is a single cell charger with two charge currents and can handle sizes up to 26650, the charger is powered from usb. I got the charger in a cardboard retail box with fairly limited printing on. The box contained the charger, a bag and a usb cable, there was no instruction sheet. The bag is for the charger and the cable. The micro usb connector is placed on the front, just below the display. The user interface is a display and a single button. A press on the button will change between 500mA and 1000mA charge current, but only when there is a battery in the charger. Holding the button down will turn off the display and disable the current change function, the charger will continue to charge with selected current. To turn display on again the button must be held down again. The display has an animated battery icon, charge percent, voltage and selected current. The charge uses the typical slider construction with a metal rail and it works smoothly from about 29.5mm to 71.5mm, i.e. the charger can handle any 18650 and 26650 cells both protected and unprotected. The charger can easily handle 71 mm long batteries, including flat top cells. Measurements
At first glance this looks like a good CC/CV charge curve with 100mA termination, but there is one serious problem: The charger do not charge to 4.20 volt, but to 4.30 volt. At 500mA charge current the problem is exactly the same. The two other cells works the same way with CC/CV and over charge. The charger has no problems with the older cell. It looks like there is some small problems with the charging at 500mA for this cell. Due to this the end result is slightly better. M1: 29,4°C, M2: 39,2°C, M3: 40,6°C, HS1: 45,3°C The battery stays cool in this charger. M1: 28,8°C, M2: 40,8°C, M3: 43,6°C, HS1: 44,1°C The charger needs about 5 second to start. The charger current can be switched at any time during charge (if the display is on). Conclusion The charger looks nice for a single cell charger and with two current settings it can handle most cell sizes, but the higher voltage makes it nearly useless (There is a few 4.3 volt batteries on the market). Generally I will not recommend this charger, but if you have some 4.3 volt cells it can be very useful (Just remember to mark the charger clearly). If Keeppower fixes the over charge and makes some way to recognize fixed chargers, it will be a good charger. Notes Using this charger will not make quality batteries explode, but it will reduce the lifetime of the batteries significantly. Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
11.10.2015, 18:33 | 2 |
Re: Test/Review of Charger Keeppower L1
Хрень какая-то.
С фонарями лажанулись, с зарядкой лажанулись... |
23.10.2015, 14:50 | 3 |
KEEPPOWER УКРАИНА
Регистрация: 30.03.2013 Последняя активность: 02.03.2022 15:51 Адрес: Сумы
Сказал(а) спасибо: 394
Продублирую ответ от Keeppower:
Dear Henrik, Wish all the best! Just review your test report of our charger L1( Thanks you very much. Nice test as usual. I think the sample you tested should be our Engineering Sample, we set of with charge to 4.30V, 4.25V for testing. It is not our finial products. We now are under amending; we will set with cut-off at 4.20V and with 0V re-setting function. We also finish 2 slots L2 LCD charger; we will send official samples to you sooner.
Всегда актуальное наличие аккумуляторов Keeppower, LG, Panasonic, Samsung, Sanyo, Sony, зарядных устройств Xtar, Keeppower, MIBOXER, а также фонари - Keeppower Украина |
23.10.2015, 14:57 | 4 |
Ветеринар Фонаревки
Сказал(а) спасибо: 9616
Поблагодарили: 2227 раз(а) в 1446 сообщениях
In Fino verytas |
23.10.2015, 18:12 | 5 |
I will be happy to test a fixed version of it and a 2 slot version. I will recommend adding some identification to the fixed version. |
23.10.2015, 18:47 | 6 |
Регистрация: 18.12.2011 Последняя активность: 01.12.2023 17:40
Сказал(а) спасибо: 1483
Поблагодарили: 428 раз(а) в 299 сообщениях
Great review, thank You HKJ.
24.10.2015, 16:05 | 7 |
Ветеринар Фонаревки
ревью то хорошее а зарядка так себе.
11.11.2015, 09:22 | 8 |
Регистрация: 04.05.2013 Последняя активность: Вчера 23:20 Адрес: Москва, Университет
Сказал(а) спасибо: 385
Поблагодарили: 237 раз(а) в 122 сообщениях
Господа! Подскажите пожалуйста, можно ли использовать данное устройство если оно заряжает до 4.27 вольта? Мне попалось такое и я опасаюсь вредных последствий. Из примерно 20 зарядок, которые у меня были, самое большое значение напряжения, которого они добивались, было 4.21 вольт. Чаще всего мне попадались зарядки заряжающие до 4.18 - 4.19 вольт.
11.11.2015, 09:35 | 9 |
старожил
Регистрация: 25.05.2012 Последняя активность: 11.11.2021 19:36 Адрес: Санкт-Петербург
Сказал(а) спасибо: 661
Использовать можно, но нежелательно, если не хотите сократить жизнь АКБ.
Klarus XT11, Thrunite Neutron 1A, Solarforce Z2/X3, Convoy S2, EagleEye X6 XPL HI, Xeno S3a v2, Skilhunt H02W Околофонарные мелочи |
Merlin (11.11.2015)
11.11.2015, 10:26 | 10 |
Спасибо! А на сколько думаете сократится жизнь АКБ при постоянном использовании зарядки заряжающей до 4.27 вольта? Что уменьшится, количество циклов или срок использования АКБ? Мне для счастья надо 100 циклов и 3 года жизни (хорошо бы емкость сохранилась при этом процентов на 70. Зарядок полно, но эта очень нравится.
12.11.2015, 03:34 | 11 |
старожил
100 циклов скорее всего продержатся, к концу емкость снизится процентов на 15.
Здесь почитайте. |
Merlin (12.11.2015)
12.11.2015, 08:55 | 12 |
Спасибо!
17.02.2016, 23:22 | 13 |
Регистрация: 17.02.2016 Последняя активность: 04.04.2016 18:40 Адрес: ярославская область
